Question about 2010 Ford Escape - 2.5L 4-cyl. engine - Performance Module
Where is the Coolant Temperature Sensor for 2010 Ford Escape
    Sergeant:
  • 243 Answers
Again, my standard answer to these type of questions is to purchase a haynes manuel from either an auto parts store or i got mine off ebay, saved 10.00. These manuels have a wealth of knowlege, diagrams and instructions to help in such a task. Good Luck.
Posted on Nov 24, 2014
How to replace a 2002 ford escape thermostat
10F0526 2002 FORD ESCAPE 3.0 - YouTube
? 0:57
https://www.youtube.com/watch?v=L3uhu66ormo
Jul 8, 2010 - Uploaded by morrisonsauto
10F0526 2002 FORD ESCAPE 3.0. ... 2002 Ford ExplorerThermostat Housing Coolant Leak Repair Part 1 ...
Jan 11, 2016 | Ford Cars & Trucks
Where is the coolant temperature sensor on ford escape
follow the top radiator hose back to where it connects to engine , the coolant sensor is the black plastic plug just to the left of where hose connects
Jan 19, 2015 | Ford Cars & Trucks
Wher is the coolant sensor fpr a 2010 focus
Clear the code and drive the vehicle. If the code comes back, then you know it's real condition and not a one time event.
Changing the temperature sensor isn't going to remedy the situation. Most likely the thermostat will need to be replaced.
Apr 26, 2014 | 2010 Ford Focus 1.6
Hola buenas tardes tengo un problema con mi ford escape 2009 motor 3.0 que las ventiladoras de enfriamiento se me an quedado directac y no hacen sus ciclos de parar cuando el motor esta frio si no que...
Necesitas un sensor de enfriamiento del ventilador. Est? ubicado en el radiador.
You need a Fan Cooling Sensor. It is located in the radiator.
2005 Ford Escape radiator cooling fan repair. - YouTube
? 3:19
https://www.youtube.com/watch?v=3Sk5g4PGVWs
Sep 24, 2014 - Uploaded by hufhuffy
2005 Ford Escape cooling fan problems ,cooling temp sensor auxiliary fan control unit ,radiator fan switch ...
2009 Ford Escape Hybrid radiator cooling fan - YouTube
? 1:42
https://www.youtube.com/watch?v=tRdrV825xak
Mar 8, 2017 - Uploaded by stevenofpa
00243 2009 Ford Escape Hybrid radiator cooling fan - This video shows the engine cooling fan radiator fan ...
2008 Ford Escape Cooling Fans: Both Aux and Main Cooling Fans ...
https://www.2carpros.com/questions/2008-ford-escape-cooling-fans Jun 17, 2014 - I have replaced the Main cooling fan relay but didn't help. Not sure if there is ... 2002 Ford Escape Coolant Overflow Bottle Replacement.
2009 Ford Escape Cooling Sensors, Switches & Relays - CARiD.com
https://www.carid.com > ... > Ford > Escape Results 1 - 21 of 21 - Ford Escape Replacement Engine Cooling Parts - 2009 ... Ford Escape 2009, Coolant Temperature Sensor Connector by Standard®. 2009 ford escape replace cooling fan sensor Google Search
Oct 28, 2017 | 2003 Ford Escape
P0128 code on 2006 ford escape, solutions?
Diagnostic Test Code (DTC) P0128 has a generic description of "Coolant Temperature Below Thermostat Regulating Temperature".
The Poertrain Control Module (PCM) checks the coolant temperature at startup. It then calculates the period of time that it should take for the engine to reach operating temperature (or thermostat regulated temperature). After the calculated period of time, the PCM again checks the coolant temperature. If it has not reached operating temperature, a code P0128 flag is set in mode 6.
If the engine still has not reached operating temperature after 5 more minutes of continuous engine operation, code P0128 is set in continuous memory and the Check Engine (or Malfunction Indicator Light "MIL" is turned on.
Possible causes:
> A stuck-open engine coolant thermostat (MOST common)
> A skewed Engine Coolant Temperature (ECT) or Cylinder Head Temperature(CHT) sensor (working, but not reading correct temperature)
> Low engine coolant level (causing the sensor to not read correctly)
First, the engine coolant (antifreeze) level should be checked. If it is low, it is recommended to perform a cooling system pressure test to find out WHY.
Then, the actual engine temperature should be measured with an infrared thermometer near the ECT or CHT. The reading from the thermometer should be checked against the live sensor data with a scan tool. (PLease note that MOST generic OBD code readers CANNOT perform this function.)
If the reading from the thermometer and the sensor data is within 10 degrees F of each other, replace the thermostat. Otherwise, the sensor circuit should be checked for high resistance (loose or corroded connector, damagd wire, etc.). If no high resistance is measured in the rest of the circuit, the sensor should be replaced.
Jan 03, 2012 | Ford Escape Cars & Trucks
Changed expansion tank but light still on any ideas 03 ford escape low coolant level light on dash stays lightup
bad low coolant switch or still low on coolant.
Engine Cooling The cooling system components are the:
  • engine coolant temperature sensor (ECT sensor) (12A648)
  • radiator (8005)
  • degas bottle (8A080)
  • radiator draincock (8115)
  • water pump (8501)
  • water temperature indicator sender unit (10884)
  • water thermostat (8575)
  • dual speed fan motor assembly
The water pump circulates the coolant.
The water thermostat:
  • controls the engine coolant temperature.
  • allows quicker engine warm-up.
The degas bottle:
  • provides a location for fill.
  • contains coolant expansion and system pressurization.
  • provides air separation during operation.
  • replenishes the engine coolant to the system.
The fan motor (8C607):
  • operates only when the ignition switch is in the RUN position.
  • will not operate with the switch in the OFF position.
The engine coolant flows:
  • from the lower radiator hose (8286) to the water pump.
  • from the water pump to the engine block and the cylinder heads.
A closed water thermostat returns the engine coolant to the water pump; an open water thermostat allows the engine coolant to flow to the radiator.
Engine coolant provides freeze protection, boil protection, cooling efficiency and corrosion protection to the engine and cooling components. In order to obtain these protections, the engine coolant must be maintained at the correct concentration and fluid level in the degas bottle.
When adding engine coolant, use a 50/50 mixture of clean, drinkable water and engine coolant.
To maintain the integrity of the coolant and the cooling system:
Dec 07, 2009 | 2001 Ford Escape
My 2007 ford escape's coolant warning light stay on . The radiator has been flushed and there is no overheating.
two types of coolant warning one is temperature other is low level....the sensor is located in the resavore tank.. look at bottom and follow wires to the sensor.. common problem
Sep 04, 2009 | 2007 Ford Escape Hybrid FWD
2010 Ford Escape - 2.5L 4-cyl. engine - Performance Module Logo
Top Jet Vehicle Parts & Accessories Experts
Roger W Stone
Level 1 Expert
Richard Warren
Richard Warren
Gil Shultz
Are you a Jet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
