My washer fiils with water when its off.
Sometimes after i do a load of wash and the washer is completly empty ill notice later that water is inside the washer up to the door.this is a front loader kenmore elite he3t.
    Sniper:
  • 68 Answers
The solonoid on the fill valve is stuck open. you can take the valve apart and see if there is any sand or small pebble blocking it from closing. if so, clean it and re-assemble the valve and test it. if that does not fix it, you will have to replace the fill valve. it is not difficult to replace the valve. let me know if this solves your problem. shane
Posted on Jun 19, 2009
    President:
  • 1,185 Answers
You have a faulty fill valve
The valves open when the machine requires water, then when power is removed they seat back down again and use the incoming water pressure to hold that seal
There is probably a bit of dirt under the seal and this will allow water to slowly fill the machine
You can strip out and strip down some valves but for the cost it is just as easy to replace them
If you machine is both hot and cold fill then you need to turn off one of the supplies (Cold) after you have used the machine and see if it stops the problem
If it does then it is the Cold Valve if it soes not then it is the Hot one
They are easy to replace and can be bought from dealers or thrird party suppliers
    Problem Solver:
  • 9 Answers
This would be your water inlet valves. located behind the waher where the water hoses attach to. I suggest you just replace them, they may be coroded and woul cheaper to replace. They are not hard to do. Just turn water of bout hoses and remove the old and take it to an appliance store and get a replacement.
Finding water in the washer after it sits idle for a few hours. Wife tells me that she completes a wash cycle as normal, moves the clothes to the dry emptying the washer. Then later in the day she returns...
yes its a leaky solenoid water inlet valve,shut off each water fill valve after using the machine and check the drum later to see if its still empty,then do the other4 valve and when you find water then thats the leaky valve,don't try to clean it,just replace the entire valve
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Uses to much water,fiils half way up the glass with water///and really uses alot of water on express wash
Set the washer with a low water level settting to confirm if the clothes are soaked in , if the water level does not go down it is possible that the water level pressure switch is faulty.
Sep 29, 2010 | Kenmore HE2 Plus Front Load Washer
I have water in my front loader when empty
Water is siphoning back in! Make sure there is a siphon break or vent at the end of your drain hose to stop this problem for sure.
May 15, 2010 | Washing Machines
Take the top off of the unit via the screws at the back of the top. the fill valves are about halfway down the back of the unit on the left form the rear of the unit. There is also an access panel in the back of the unit that might be easierfor you to get to it with
Sep 13, 2009 | Kenmore Washing Machines
My washer fills VERY slowly and will not stop filling after cycle
It sounds like the water inlet valve is stuck partially open and needs to be replaced. It's located on the back of the machine where the hoses attach.
Jun 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
After washing cylce complete; 3-4 inches of water is left
it sounds as tho water is getting intyo machine after use. there are 2 possible causes.
either
inlet valve leaking. turn water off and see if this stops water accumulating. if it does, then you need to replace valve to cure.
or
if drain is plumbed into spigot on sink trap then every time you drain sink, some of the water goes down the drain hose.
to cure, take the drain hose up as high as possible in a swan neck
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ammana nav8805e
If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
