Question about Respironics EverGo Battery Charger
Blowing 30 amp fuse when connected to cigar lighter
When using the machine in the car on the cigar lighter it blows the 30 amp fuse after around 5 minutes
Ford fiesta 1.2 zetec 2012 as soon as you plug anything in cigarette lighter socket it blows 20amp cartridge fuse f30 must be a short carnt find any wire colours from fuse box to trace, not in manual.
Maybe something wrong with cigar lighter socket? The top wire is voltage, bottom is ground for cigar lighter. If the voltage circuit was shorted to ground, it would blow the fuse w/o anything plugged in. If the component your plugging into the cigar lighter is drawing too much, it will blow the fuse.
Aug 21, 2017 | Ford Cars & Trucks
I have replaced the #17 fuse (20 amp) numerous times and the cig. lighter twice
Try disconnecting the cigar lighter altogether to see if the fuse continues to blow. If it keeps blowing, you have a short somewhere in the wiring, if not the lighter is causing the problems.
May 03, 2016 | Cars & Trucks
Ciger lighter position 41 keeps blowing 47 ok
AUX PWR Fuse #41
20A
Auxiliary Power Outlets - this not Cigar lighter ,the power outlet is bad. replace it or short to ground in wiring.
CIGAR Fuse #47
15A
Data Link Connector, Cigar Lighter
the power
Nov 08, 2015 | 2000 Chevrolet Silverado
Using cigarette lighter for air pump
It is very likely the cigar lighters circuits wiring sizes are not suitable for the amp draw of the compressor, i suggest you not use it as a power source. Buy clip leads and solder them on and use the battery as the power source. You can obtain the electrical clips from any hardware store.
Jul 23, 2012 | 2006 Honda Jazz 1.5
Cigertte lighter
I am not exactly sure of your problem of just saying cigarette lighter, but I assume you are saying it is not working. If this is the case, most likely it is a fuse. Look in manual if you can not find right fuse or where fuse panel is. However the fuse will be marked as cig or cigar and if that is so, pull out fuse, and replace it with same amp. It will be marked. The fuse you can easily get at any auto parts store, such as shucks, or Napa, or auto zone. Cig lighters often blow because with all these devices now a days we plug in them, they get a lot more use then years ago. For example they were actually designed originally to light cigars or cigs, but now we are plugging in i phones, computers, phones, etc,,,, so they get a lot more use and sometimes we overload the fuse and blows. I tell all my customers that it is nice to have a couple back of cig fuses in the car. There real cheap they normally come in a little tiny plastic pill size clear box, and run under 5 bucks and normally at least 5 fuses in the box. I hope this helped your problem, again I was assuming by your only posting of your problem stating cigarette lighter, Please let me know if this advice helped, or if not, let me know what else i can do for you, thanks Mike
Jun 26, 2011 | 2000 Ford Focus
How do i locate fuse for cigar lighter in 2003 mondeo lx tdci?
in fuse box, try to remove one by one and check if ok or not, also there should be a layout of fuses on cover of fuse box.
May 04, 2011 | Ford Granada Cars & Trucks
My power outlets and cigarette lighter outlet do not have power. Which Fuses should i change.
chek on the fuse box for Accessories/ cigar lighter, usually this is 10-15 amps rating. Use a long nose plier to check this out and replace. if the fuse blows off again you must check out the lighter for shorting.
Jun 30, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
Same problem as problem already posted. the cd player, radio, and clock are blacked out and wont power up. every time i install a 15 amp fuse it blows, please help
is the cigarate lighter is also not working ? if the case then try using new lighter or mobile charger. if not then just remove the socket of radio and then place the fuse if it is blowing then problem with wire got short some where with body if it is not blowing then replace radio.
Jan 21, 2010 | 2002 Toyota Tundra
88 Buick Park Avenue - Radio, Heating/Ac pannel & lighter are out. Thinking it could be fuse? Any other thoughts & are these on same fuse system.
They are usually not on same fuse..something may be making multiple fuses blow..check the fuse box and see if any are blown.
If your just talking about the lights on those items they are all on the same fuse check the fuses...often a bad cigar lighter socket will cause the fuse to blow
Aug 27, 2009 | 1988 Buick Electra
The cigar lighter isn't working how do I fix this problem
This is a fuse problem, check the fuse, it will either be marked lighter or power point, the fuse box is to the left of the steering column it has a plastic cover over it, inside the cover the fuses will be marked on a diagram. If the fuse blows again the cigar lighter is shorted, you will have to replace it, most times the lighter element is the problem and not the well it fits into.
Oct 16, 2008 | 2003 Buick Regal
Respironics EverGo Battery Charger Logo
Top Respironics Health & Beauty Experts
David Payne
David Payne
 Bob S
Bob S
Level 1 Expert
Are you a Respironics Health and Beauty Expert? Answer questions, earn points and help others
