Question about Panasonic DMR-ES35VS
Disk won't read
Clunks four times or so the message "no read"
2 Suggested Answers
SOURCE: On my DMR-ES35 Panasonic after perfect operation for 18 months, I'm getting a NO READ message, on disks already recorded on this unit,and several new disks of different makes. The main sympton now is
Same problem. "NoREAD" after about 15 months of moderate usage. Cleaned laser eye thoroughly. Solution is a class action lawsuit against Panasonic.
Posted on Nov 08, 2008
Heard a clunk while driving diesel ford excursion now when drive and reverse don't work....any ideas what problem is?
If it is a four wheel drive check your tail shaft or drive line by securing the vehicles front wheels jack up the rear tires and in park try to rotate the drive line if you can hear the transmission sound like it is going into gear the transfer case could be damaged! If not a four wheel drive pull the transmission dipstick and look to see if the fluid is dark red or metallic grayish color if so then you're clutch disks inside the tyranny have been worn out and it needs to be rebuilt!
Oct 05, 2014 | Cars & Trucks
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Console won't read disk. when disk in console, message comes up unable to read disk
If you are getting that message then there is likely 2 reasons.
1: is because your disk is scratched up or something.
2: your disk reader that is inside of your Wii Console is out of place.
Oct 06, 2011 | Nintendo Wii Console
DVD writer after loading the disk makes a series of clunking noises as it attempts to read the disk - after about 20-30 seconds it stops and the green light goes out - fails to show up on desk top or in...
May need to clean the laser, or it may be a disc that
drive doesn't read You need specs as to what drive writes to and reads to
Nero info gives this information
Feb 15, 2011 | LaCie (300736U) DVD±RW Burner
I hear a clunking noise each time i run over a bump in the rear end of my car.
Well if your spare is in its place got and tight and you don't have anything in your trunk that could make the clunking noise it sounds like your rear struts need to be chaanged,well at least one if you know what side the noise is coming from and it is better to change both at the same time and when you have the struts changed figure in a four way alignment.When you align the back most alignment machines are set up to do only front or all four not just the back.That way you don't wear out your rear tires prematurely.
Apr 19, 2010 | 2004 Toyota Camry
I have a 1999 GMC Suburban. I have automatic four wheel drive but when I shift into four wheel high it makes clunking sound. I have not tried four wheel low. I wondered why I can still use auto four wheel...
the auto 4 wheel does the same as part time in jeeps, it engages only when the vehicle loses traction. when auto 4 wheel is on the truck isn't fully in 4 wheel drive. my 02 sierra makes the clunk noise too but it does engage. try checking your fluids, i know its way pass the time for me to change mine out.
Feb 09, 2010 | GMC Suburban Cars & Trucks
Jan 21, 2008 | Panasonic DMR-ES35VS
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMR-ES35VS Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
