Question about Dell 810 All-In-One InkJet Printer
When ink was replaced my printer will scan but not print
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
I installed the drivers for a canon pixma mp210 and it wont scan. it keeps saying " E 1 6"
"E 1 6" error code means Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Jun 11, 2011 | Canon PIXMA MP210 InkJet Printer
When I Turn on my Canon Pixma Mp210 the error 6 pops up. I try to restart my printer, but it didn't help. What this error means and what to do?
Issue: ERROR LED: E, 1, 6
Solution: Press and hold Stop/Reset button for at least five seconds
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
Solution: Replace ink cartridge(s) MP210
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
    *MP470 shown
  2. Press down on the semi-circular tab (circled area in <1>, above) to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  5. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  6. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  7. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  8. Fold the scanning unit support and close the scanning unit (printer cover).
  9. Wait until the preparatory operation is complete; it takes about one to two minutes.
Trust this is helpful. :)
Dec 10, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My large black ink cartridge with not print correctly on my Canon Pixma MP830. All the other colors work fine. I've done numerous cleaning and deep cleaning. Then replaced the cartridge and it still prints...
Are your black ink cartridges genuine Canon ones?
Are the contacts clean when you remove the cartridge?
If not blow off with compressed air and a clean brush, if necessary.
Canon.com's site covers the verification that the cartridges are installed correctly below:
Issue: Black ink does not print
Solution: Confirm that the recommended ink tanks are installed properly MP800R / MP830
Replacing an ink tank When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. Recommended Ink Tanks:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
    Note:
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Check the ink tank. If the orange tape is as shown in Figure <1>, it is properly removed. If the tape is not removed (as in figure <2>, pleease remove the extra tape).
  6. Insert the ink tanks into the print head.
    Note:
    Press the mark "PUSH" on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  8. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Jul 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How do you remove used ink cartridge?the printer is out of black ink
Removing the Print Head / Ink Tanks Instructions to properly remove the print head or ink tanks. Remove the ink tanks before proceeding to remove the print head.
Remove the Ink Tanks
  1. Confirm that the printer is powered on.
  2. Pull open the paper output tray.
  3. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  4. Open the inner cover.
  5. Remove the ink tanks by pressing the tab of each tank.
Click to return to the top.
  1. Raise the print head lock lever.
  2. Tilt the print head slightly towards the front of the machine and lift out gently.
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson RX600 will not scan or nuthin' with empty ink cartridges
I cannot help about the Printing problem, because it seems it needs to have all the catridges with some ink to Print.But i can help you about the scan problem.I was having the same issue as you and gave up trying to print, but when i needed to scan i realized the printer didnt let me touch any of the buttons, repeating the same message "change catridge".If you use the EPSON SCAN application that comes with the printer, it lets you scan directly from the PC. It takes longer, dont know why, but at least it scans.I hope it helps.
Jan 10, 2009 | Epson Stylus Multifunction Printer/...
Ink cartridge problem
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Dell 810 All-In-One InkJet Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
