Question about GE PSC23NSWSS Profile Counter-depth 23.2 Cu. Ft. Stainless Side-by-Side Refrigerator
Temperature calibration The temperature is on 48. How can i lower the temperture to 37?
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: model #PSC25MSTA SS - one year old, never got a
Had a problem similar to this with this frig and the problem was a bad mother board that kept the fans from operating correctly to disperse the temperature. I woould actually get stalagtites forming from the warmer top shelves to the colder lower shelves. Repaire under extended warantee.
Posted on Feb 12, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Freezer won't maintain temperature any lower than 16-18
It appears that your refrigerator is missing defrost. It will be difficult for anyone to provide photos of your defrost heater. I recommend that you unplug long enough to allow defrost to begin manually so we can get freezer door open and remove frozen goods long enough to place somewhere safe until we examine the defrost heater and defrost thermostat. At this point the only pictures will be the ones you email me. This appears to be a new breed of Profile from GE. If you would like to attempt this please let me know. The defrost heater is part number WR50X10043 but that means nothing until we do some testing, Let me Know, Sea Breeze
Posted on Mar 23, 2010
  • 187 Answers
SOURCE: warm temperture freeze
Check if you are getting power to freezer Check if compressor is running
Check if condenser and evaporator fans are runing
Check all controls someone might have moved one
Chec the cold control could be bad not turning it on you could put a clip lead across the connections and see if it comes on.
Feel the lines on the compressor one should be real hot the other should be cool.
Check evaporator frost should be all across it if frost halfway freon could be low.
Be sure it is not in the defrost cycle it will do this every so many hours depending on where it is set Hope some of this helps
Posted on Jul 16, 2010
  • 12744 Answers
SOURCE: Refrigerator temperature is 30. We cannot set it
check the fan that runs between the freezer and fridge in the fan housing is a damper that opens and closes if ice or debris is blocking or in way clear so damper can open and close the fridge is cooled by the freezer
Posted on Jul 20, 2010
How do I find the fuse on an impala 2002 for the.outside temperature and compass
There are two fuses one in the right I/P junction block an one in the left I/P junction block ! The right is marked DK / RKE 10amp fuse. The left is marked A/C / CRUSE 10amp fuse ! I don't think these are the problem ! These fuses supply power to the microprocessor in the driver information center . According to my service information the microprocessor supply's power to the ambient air temperature sensor an to the compass.
This mode displays an 8 point compass heading on the left hand side of the DIC. The compass will display the current vehicle direction relative to one of 8 compass headings using N, NE, E, SE, S, SW, W, and NW for the readout. The ambient temperature displays on the right hand side of the DIC. If the ambient temperature is below 3?°C (37?°F), the temperature reading will toggle between displaying the outside temperature and the word ICE for two minutes. If the temperature is less than minus 40?°F for more than 2 seconds, OC will display. If the temperature is above 140?°F for more than 2 seconds, SC will be displayed. If OC or SC is displayed DTC's will be set. For compass calibration and compass magnetic variation adjustment refer to Electronic Compass Calibration .
Feb 28, 2015 | 2002 Chevrolet Impala
Tip
Detroit Diesel Fault Codes
Code Description DDEC V Circuit
11 P 187 4 Chain PTO. Short circuit in the power
11 P 187 7 control system PTO wrong answers
12 P 187 3 Chain PTO. Short circuit in the ground
13 P 111 4-level circuit antifreeze. Short circuit in the ground
13 P 111 6 second-level circuit antifreeze. Short circuit in the ground
14 P 52 3 circuit coolant temperature intercooler. Short circuit in the power
14 P 110 3 circuit temperature antifreeze. Short circuit in the power
14 P 175 3 Chain oil temperature. Short circuit in the power
15 P 52 4 circuit coolant temperature intercooler. Short circuit in the ground
15 P 110 4 circuit temperature antifreeze. Short circuit in the ground
15 P 175 4 Chain oil temperature. Short circuit in the ground
16 P 111 3-level circuit antifreeze. Short circuit in the power
16 P 111 5 second circuit level antifreeze. Short circuit in the power
17 P 51 3 Throttle position circuit failed high
17 P 72 3 Bypass position circuit failed high
17 P 3 354 Relative humidity sensor circuit failed high
18 P 51 4 Throttle position circuit failed low
18 P 72 4 Bypass position circuit failed low
18 P 354 4 Relative humidity sensor circuit failed low
21 P 91 3 TPS circuit failed high
22 P 91 4 TPS circuit failed low
23 s 65 3 Oxygen content circuit failed high
23 P 174 3 Chain fuel temperature. Short circuit in the power
24 s 65 4 Oxygen content circuit failed low
24 p 174 4 Chain fuel temperature. Short circuit in the ground
25 no codes
26 s 25 November Aux. shutdown # 1 active
26 S 61 11 Aux. shutdown # 2 active (Incorrect SID. subject to change)
27, p 105 3 circuit temperature in the reservoir. Short circuit in the power
27 p 171 3 Ambient air temp circuit failed high
27 p 172 3 Air temp, circuit failed high
28, p 105 to 4 Chain manifold temperature. Short circuit in the ground
28 p 171 4 Ambient air temp circuit failed low
28 p 172 4 Air temp, circuit failed low
29 p 404 4 TCO temperature circuit failed low
29 p 351 4 TCI Temperature circuit failed low
31 S 51 3 Aux. Output # 3 open circuit (high side) S3
31 S 51 4 Aux. Output # 3 short to ground (high side) S3
31 S 51 7 Aux. Output # 3 mech. system fail S3
31 s 52 3 Aux. Output # 4 open circuit (high side) T3
31 s 52 4 Aux. Output # 4 short to ground (high side) T3
31 s 52 7 Aux. Output # 4 mech. system fail T3
32 S 238 3 SEL short to battery B1
32 S 238 4 SEL open circuit B1
32 s 239 3 CEL short to battery B2
32 s 239 4 CEL open circuit B2
33 p 102 3 Boost pressure circuit failed high
34 p 102 4 Boost pressure circuit failed low
35 p 19 March Ext range oil pressure circuit failed high
35 p 100 3 Chain oil pressure. Short circuit in the power
36 P 19 April Ext range oil pressure circuit failed low
36 P 100 4 Chain oil pressure. Short circuit in the ground
37 P 18 March Ext range fuel pressure circuit failed high
37 P 94 3 Chain fuel pressure. Short circuit in the power
37 P 95 3 Fuel Filter Restriction circuit failed high
38 P 18 April Ext range fuel pressure circuit failed low
38 P 94 4 Chain fuel pressure. Short circuit in the ground
38 P 95 4 Fuel Filter Restriction circuit failed low
39 S 146 2 Mechanical error EGR valve
39 S 146 12 Mechanical error EGR valve
39 S 146 return valve 7 does not meet the exhaust
39 S 147 2 turbocharger control mechanism does not respond
39 s 147 12 turbocharger control mechanism does not respond
39 s 14 147 current returns exhaust gases enough
39 S 147 11 turbocharger control mechanism does not respond
39 S 147 7 turbocharger control mechanism does not respond
41 S 21 0 Too many SRS (missing TRS)
42 S 21 January Too few SRS (missing SRS)
43 p 111 1 Low coolant level
44 p 52 0 ntercooler coolant temp, high
44 p 105 0 temperature in the reservoir above the norm
44 p 110 0 antifreeze temperature above normal
44 p 172 0 Air inlet temp, high
44 p 175 0 Oil temperature above normal
45 p 19 January Ext range oil pressure low
45 p 100 1 Oil pressure below normal
46 p 168 1 Low voltage batteries
46 S 214 1 RTC Backup Battery Voltage Low
46 S 232 1 Sensor Supply Voltage Low A3 & W1
P 0 47 18 Ext range fuel pressure high
P 47 94 0 The fuel pressure above normal
47 p 0 102 Turbo boost press high
47 p 106 0 Air inlet pressure high or TCBV diff press high
47 p 164 0 Injection control pressure high
48 p 18 January Ext range fuel pressure low
48 p 94 1 fuel pressure below normal
48 p 106 1 Air inlet pressure low
48 p 164 1 Injection control pressure low
48 p 351 1 TCI Temperature below range
48 p 404 1 TCO Temperature below range
48 p 411 1 EGR Delta pressure low
48 p 412 1 EGR Temperature low
49 p 351 0 TCI Temperature above range
49 p 404 0 TCO Temperature above range
More Fault Codes here Detroit Disel DTC
on Dec 20, 2016 | Cars & Trucks
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
Aug 04, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Trouble adjusting the water temperature for the Grohmix. I cannot get much coldwater.
hi
does the water flow decrease when you lower the temperture?
is there a pump on it?
remove the thermostat housing,their should be a grub screw on the side.
pull the housing off the spindel.
turn the spindel anti clock wise.the more you turn the lower the temperature.
refit housing
turn shower on and test
more info is required if this does not solve the issue
Dec 18, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
How can lower my refrigerator temperature to 37?
You need to unplug your unit for 24hrs. You need to clean out the fins with air compressor and vacuum. This has worked wonders for my 550.
Jan 04, 2010 | Sub-Zero Bottom Freezer Refrigerator
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Stove won't go below 170
The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE PSC23NSWSS Profile Counter-depth 23.2 Cu. Ft. Stainless Side-by-Side Refrigerator Logo
16 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
