Question about ACCO Brands Kensington o - Laser Si750m LE Wireless Notebook Mouse, Three-Button, Metallic Pink
Mouse stopped working
Battery is OK. Green light appears when removing from mouse, USB port working. Mouse stopped working. Still doesn't work after rebooting.
  • 42 Answers
Check underneath for dirt or debris blocking the laser light lens, try on a different surface ie (mousepad). If that doesn't solve your problem, it's time for a new one.
Posted on Jun 19, 2009
My Logitech LX3 optical mouse has stopped working completely. If there is a battery in it where the heck is it? I don't see anywhere on the mouse where a battery could fit in it. Please help! Francine
The LX3 is a wired USB mouse so it doesn't have a battery. So the next issue: is the mouse plugged in directly to the computer or into a USB hub? Try changing the port that you have the mouse connected. Check that the USB ports are active (not disabled for power savings or security) For Windows, the first is under the Advanced settings for the Screen Saver. The second is in the device manager. Try the mouse on another computer if possible. Try a different mouse on the computer. Check if other USB ports work with known working devices. For a Windows machine, you might try uninstalling the USB device and then reinstalling the drivers after a reboot. For laptops, try resetting the unit. On my HP laptop, I lost all USB devices at once for a part of the day. In that case, unplugging the AC charger and removing the battery was required to recover the USB ports.
If you have an older OS, make sure the drivers are installed. (This mouse is not compatible with Windows 95.) If you use a USB to PS/2 adapter, try a USB port and reboot the computer.
Wired mice frequently get damaged cables so I'd recommend replacing it. There was a 5 year warranty on the mouse when purchased new.
I hope this helps.
Mar 20, 2011 | Logitech LX3 Optical Mouse
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Receiver light is steady green. mouse won't light up. cursor won't move.
Why don't you try at the moment of placing a new battery to see if the small button that protrudes, where the receiver is located at the bottom of the mouse is pressed down. Without the receiver in place that **** on must be out for as long as the receiver is in the USB port.
Good luck!!!
Chawah.
May 19, 2009 | Microsoft Wireless Notebook Optical Mouse...
Logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Mar 01, 2009 | Logitech Cordless Mouse
My mouse stopped working, changed the batteries, reset the link button, started working, went away from the computer and now it isn't working. Tried resetting the link button, nothing is happening.
do you have pets or live with other people with access to the pc?
have you tried rebooting?
sorry if it seems basic, but first things first.
Jan 29, 2009 | Computers & Internet
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Microsoft Wireless Notebook Optical Mouse Not Connecting
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Apr 05, 2008 | Microsoft Wireless Notebook Optical Mouse...
ACCO Brands Kensington o - Laser Si750m LE Wireless Notebook Mouse, Three-Button, Metallic Pink  Logo
212 people viewed this question
Top ACCO Brands Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
handyguy54
Level 1 Expert
Are you an ACCO Brands Computer and Internet Expert? Answer questions, earn points and help others
