Question about Electrolux Centralux Vacuum
Red Service light is on?
Model E130J canister and filter are clean
Red power light blinks even with completely clean canister and filter
Check for a filter where the air blows out of the machine. Could be clogged.
Jul 26, 2013 | Hoover S3755 WindTunnel Bagless Canister...
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
Red Light lit and it refers me to owner's manual.
Your problem could be many things, causing it to over heat, you need service by and Certified Tech. You can call the home office at 800-344-1840 to find an Authorized Service Center near you. Do not take it to a vac shop or you could end up with more problems than before.
FQ Master
888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Jun 07, 2009 | Filter Queen Majestic Canister Vacuum
Red light for HIPPA filter won't go off
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Oct 25, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Noise
The high pitched noise could be because the vacuum is loosing airflow. does the red light come on on the top? if it does ot emptythe vacuum, replace the cone filter, the secondary filter, and the batting in the top of the machine. also hook the hose to the top of the vacuum to make sure there are no clogs in the hose.
Aug 23, 2008 | Filter Queen Majestic Canister Vacuum
Red light comes on Filter Queen Majestic
Does it do this with the hose off? If it only does it when the hose is hooked up to it, then you have a clog in the hose.
Feb 09, 2008 | Filter Queen Majestic Canister Vacuum
Electrolux Centralux Vacuum Logo
241 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
