Question about Intex Seahawk II Boat Set
Puncture On the sidings
Defy problems
Do you have a neighbour who hates you? I do ride bikes for 60 years now, and never had two punctures in a row within half a year. Actually last 10 years only one puncture in one of my tires, and from the place I could deduce someone had pressed something sharp from the side into the tire. So nothing from the oad.
And the newer tires, are almost not to puncture when driving on a road. It must be someone punching in these holes. Because if some sharp thing pointing up on your road your front tire would have been punctured at least once or twice too.
Jun 22, 2014 | Giant Defy 2 Compact Road Bike 2013 - road...
Is it possible to repair a small puncture in the freon line inside a small fridge
The hole can most likely be fixed with epoxy and a filter drier added to the refrigerator by an experienced refrigerator technician but the problem involved will be the cost to have the repair done. It would be less expensive to replace the refrigerator, Thanks Sea Breeze
Dec 04, 2012 | Haier Black and Decker 2.7 Cu. Ft....
We have a dometic refrigerator in our Rv. There is an odor (similar to ammonia) when the freezer compartment is opened. The shelf has staining and blue markings around the fixtures securing it to the...
It sounds like you might have punctured a freon line. But since the cooling lines are on the back and the shelfs are secured from the sides, was something added that could puncture the line? You might want to unplug everything and turn the unit off and then try to feel the coils to see if you can detect a puncture. It is easiest to work on with the unit out but that can be very involved. And repairing a puncture or recharging the unit should be done by trained technicians.
Jul 24, 2011 | Dometic RM2652 Refrigerator
How to remove rear wheel to have puncture repaired please.
  1. Turn fuel tap off.
  2. Remove both side panels.
  3. Lay scooter on engine side ( on some kind of blanket or mat to protect the bodywork. don't forget handlebars and front mudguard.)
  4. Remove the 5 nuts holding the wheel to the hub with a 13mm socket. (make sure you remove the hub nuts and NOT the 5 which hold the two halves of the wheel itself.)
  5. Slide and wiggle wheel out past the exhaust.
  6. Do the above in reverse when puncture fixed.
Sep 25, 2010 | Peg Perego Vespa Scooter
Puncture back wheel
you take the wheel off by pushing in a button at the side of the wheel on the inside, it is a quick release wheel and it simply clicks back in when it's been repaired. hope this helps!!
Jun 06, 2010 | Quinny Buzz 3 Sulphur Jogger
I want to know if it's safe to drill three 1 inch holes in the side panel of my magic chef rb19k-4a refrigerator. I was told that I need to find out if the side panels contain any condenser coils or...
DO NOT DRILL!!
There are lines in the side of you refrigerator that if punctured will turn you refrigerator from a cooler in to a smoker.
Apr 08, 2010 | Refrigerators
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Putting refrigerator lock on freezer door
he may have punctured a freon line you will know for sure if it stops cooling.
Jan 31, 2009 | Magic Chef CTF2125 Top Freezer...
I was vacumming the coils under my whilpool side by side when I believe I heard a faint whistle along with a odorless thin white smoke that stayed low to the ground. The compressor is hot to the touch, yet...
yes it sound like you did puncture the refrigerant line to your unit, if you have a sorae refrigerator I would proceide in relocating the stuff and call a service company out to repair the leak.
Dec 27, 2008 | Refrigerators
Intex Seahawk II Boat Set Logo
73 people viewed this question
Top Intex Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Intex Boating Expert? Answer questions, earn points and help others
