Question about LG DLG2525S Electric Dryer
How do you remove the knockout panel on a kenmore dryer to attach a vent
2 Suggested Answers
  • 36 Answers
SOURCE: dtyer load and air not venting to outside vent
The blower motors on these dryers can be packed with lint. It is a fire hazard. The entire front of the dryer has to be removed.
Posted on Jul 04, 2010
How do I change the exhaust venting from rear to side on a Maytag Model MGD7500AWW?
you should see a knockout panel or cover at the side, remove this and fit vent to side.
It is important that you blank off the outlet where the hose was fitted originally
May 18, 2018 | Maytag Dryers
I have an old kenmore model 002586 dryer that just stopped and won't start. I think it may be a thermal fuse, but am not sure exactly where it is located. Would you know?
Unplug the dryer.
Remove the rear panel of the dryer.
Look on the left side of the main exhaust vent. The fuse is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
2 wires attached.
Sep 09, 2010 | Kenmore 67632 Electric Dryer
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
How do you change the air flow from the back to the side? maytag preforma
inspect the dryer sides,and see if there is a knockout to remov to allow side venting,some dryers are not side ventable,if the knockouts are there, you may need a kit from maytag specifically for that model...the installation instructions may be helpful if you have them,could provide kit no.,and the how to instruct.
Mar 06, 2010 | Dryers
Need to move the dryer vent on LG DLE5955 to the side opening.
you shouldnt have to buy anything. remove the access panel in tne rear. remove the knockout from the side panel and relocate the exhisting hdwre.
May 03, 2009 | LG DLE5977 Electric Dryer
I have a kenmore electric dryer.When I push to start ,the timer ticks but do not start.The door switch is working.When I open the door the ticking stop.What can this be?
Replace the thermal fuse located on the rear of the dryer.
Remove the rear panel the thermal fuse is white about 1 and 1/2 inches long by 1/2 inch wide.It is on the exhaust vent on the left side near were your connecting vent attaches.
Apr 12, 2009 | Kenmore Dryers
The kenmore series 70 dryer stopped running aand i can't get it
Unplug the dryer.
Remove the rear panel and check the thermal fuse attached to the left side exhaust vent. The fuse is 1 and 1/2 inches long by 1/2 inch wide and white in color.
No continuity on a volt meter is a bad fuse. Replace it.
Apr 05, 2009 | Kenmore 73952 Gas Dryer
Change dryer vent from side to rear
Not all dryers have the facility to vent out of the side, if they can , you should see a knockout panel or cover at the side, remove this and fit vent to side.
It is important that you blank off the outlet where the hose was fitted originally.
Plz rate my answer.
Thanks..
Jan 20, 2009 | Dryers
41780042990 Kemore electric dryer
you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
LG DLG2525S Electric Dryer Logo
96 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
