Question about Blodgett Blodget Kiosk Convection Oven Kco-25e-aa
Heat Doesnt seem to get to the required temperature
  • Blodgett Master
  • 3,368 Answers
Try setting it about 100 degrees warmer then what you want. If it gets to the temperature you want it is probably a bad thermostat, if not probably a bad heating element. I am not familiar with the unit.
Posted on Apr 29, 2014
What is the btu
British Thermal Unit which is a somewhat archaic measurement of heat output. I seem to remember there is a difference between btu and Btu.
One British thermal unit is the amount of heat required to raise the temperature of one pound of water by one degree Fahrenheit.
Mar 04, 2015 | Heating & Cooling
What might be wrong with my Kenmore dryer which doesnt heat? The drum turns but will not heat.
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 29, 2014 | Dryers
My dryer heats but doesnt stop wben timer is set
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Sep 11, 2014 | Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
I have an 02 dodge grand caravan where the heater blower does not come on. the infrared three-zone automatic temperature control panel does not light up as well.
if NO heat comes out,have you checked to see if the flapper(door that opens to let heat out)opens or any obstructions????. Alberto
Feb 12, 2014 | Dodge Grand Caravan Cars & Trucks
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Apr 19, 2008 | Ovens
Blodgett Blodget Kiosk Convection Oven Kco-25e-aa Logo
Top Blodgett Kitchen Ranges Experts
Gil Shultz
ray gallant
Mister Danger
Are you a Blodgett Kitchen Range Expert? Answer questions, earn points and help others
