Question about Vehicle Parts & Accessories
I have an alarm on my van the alarm key is malfunctioning do they sell replacement keys that u can maybe program to the alarm
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
Yes, but you will need to call the manufacture of the alarm and talk to custmoer service.
Posted on Jun 19, 2009
Alarm system for 2005 heritage softail deluxe
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
SMART Key Fob Programming
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 20, 2012 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
REMOTE KEY LOCK DOES NOT WORK BATTERYS NEW BUT ALARM WILL NOT SHUT OFF WHEN FIRST START .HOW CAN I DISABLE ALARM
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Carry out the following within 1 minute: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
How
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Remote controls can also be programmed using diagnostic equipment.
Feb 09, 2010 | 2000 Volkswagen Beetle
Replaced battery now having problems with automatically locks
Synchronization
When
How
Programming
When
How -
98MY
Keys can only be programmed using diagnostic equipment.
How - 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Feb 05, 2010 | 2002 Volkswagen Passat
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
I recently took my 1998 Plymouth Grand Voyager SE van to a dealership and they installed a new BCM (Body Control Module)because my doors and interior lights were not working, etc. After driving it home and...
ALL YOU NEED TO DO IS LOCK AND UNLOCK THE DRIVERS DOOR WITH THE KEY, THIS DEACTIVATES THE FACTORY ALARM SYSTEM, AND YES YOUR VAN DOES HAVE A SECURITY SYSTEM AND A TRANSPONDER KEY, IF THE PROBLEM CONTINUES YOU WILL NEED TO HAVE THE DEALER RECHECK THE WORK THEY DID, THEY HAVE TO PROGRAM THE MODULE FOR YOUR CARS SECURITY CODE, MAYBE THEY DID THAT WRONG, UNTIL THEY RETEST THE BCM THERE IS NO WAY WAY TO KNOW WHAT THE PROBLEM IS HERE, THE BCM CONTROLS THE FACTORY SECURITY SYSTEM ON THIS VAN, SO ASSUME THE PROBLEM IS WITH THE NEW BCM'S PROGRAMMING...
Nov 06, 2009 | Plymouth Grand Voyager Cars & Trucks
Alarm goes off when key open the door
Dealer is correct that you have too replace the bcm, so i would tell you to call junk yard and get one. Cheap $ 50.00 put it in by yourself. Right hand side of the glove compartment. behind the fuse box with couple connectors on it, or have some person with knowledge to do it.
Apr 02, 2009 | 2003 Chevrolet Venture Passanger
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
