Question about Proscan Televison & Video
My proscan model plcd5085a tv wont turn on
I can't get power to the tv and all the cables are inserted properly.
SOURCE: Proscan TV Manual
I have a Proscan model # PS36800HRJX1 and having a hard time putting it on DVD mode to be able to play a movie. I just bought a remote for it and can't figure out what's the problem. How do I go about it?
Posted on May 24, 2008
dsacco86
  • 1077 Answers
SOURCE: will not turn on no power proscan tv model no 26la30q
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 20, 2009
FSAhead2
  • 214 Answers
SOURCE: does the Proscan 47" LED
yes it does , if you are viewing the TV from the rear it is located in the back on the lower right , on the right side of the RCA's . here is a link to give you a visual , just wait for the manual to pop up .
http://www.managemylife.com/mmh/owner_manuals/15565/PROSCAN-LCD-Television-L1001098
Posted on Jan 28, 2011
Slinteriors
  • 8617 Answers
SOURCE: need to buy a power supply 12V 5A for a Proscan LCD TV Model 19LA20Q
www.tvrepairworld.com will most likely have the board you need.
Posted on Apr 22, 2012
SD Tech
  • 14553 Answers
SOURCE: i have a 42" Proscan standby light comes on but the tv wont turn on
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo
Posted on Aug 27, 2012
My proscan 42la45h model lcd the tv has power but wont turn on. Any suggestions
check fuses. if it turns on via remote control replace batteries. First remove from mains / power for a good ten minutes and see if this brings any benefit. There is not a lot to go wrong with fp tvs really.
If the issue is not one of these, and it does turn on via remote it might be that the control handset is faulty.
After this you can think about getting the set itself diagnosed/inspected
May 29, 2015 | Proscan Televison & Video
Proscan tv will not receive or recognize cable or video signals when all plugs are in as prescribed. Have removed power supply waited to attempt to clear it. Restarted and still get no signal message. We...
Here are a few ideas:
  • The No Signal, No Source or No Input message will appear on your television screen when the television is not receiving a signal from your Digital Box. This is often a result of either the Digital Box being powered off, not being properly connected to the TV, or if the TV is set to the wrong input.
  • Press the "TV/VCR" button on your remote control if you are experiencing no picture. This button will allow you to toggle between TV and VCR screens and may solve your display problem.
  • Make sure your cable box is turned on.
Jan 21, 2018 | Shopnbc Proscan 32" 720p 60Hz LCD HDTV w/...
Tv turns off then back on,, now it wont turn on at all
1. is the tv connected to pvr ordvd or is it directly connected to wall cable.?
2. is power cord properly inserted at both ends?
3. try direct cable connection to wall to check if ok. Then reconnect to other devices.
Aug 07, 2013 | Element Electronics ELCHW261 26 in. TV
I have a 47" Proscan
Right now the standby 5vdc power supply for the processor on the main board is working (the standby power supply and the processor are running 24/7, even when the TV is OFF) but nothing else, and since you cannot even turn on the TV at the TV control panel it may mean that the main board is not functioning.
I would inspect the power supply module first though just to make sure it does not have any bad caps, burnt parts since bad DC can make the TV to have strange symptom.
Please read my guides first to understand more.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 13, 2011 | Proscan 47LB45H 47 in. LCD TV
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Hi my name is lily i have a ploblem with my tv is proscan 19inchla25q i try to turn it on but it wont go on the red ligt flashes gree then it turn back on in red
The power supply is bad. It supplies enough power to light the red LED when the tv is powered off, but not enough to power up the tv. You can find one on ebay.
Jan 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
Proscan 36 inch tv
Good day.
The spark the you see means that your wall socket is loose. Have it fixed by a qualified technician. With regards to your unit, it has an internal problem. In my experience, the power supply is not dissipating power to the circuitry. The problem is contained in the power supply, have it checked by a technician.
chris
Mar 04, 2008 | Proscan PS36500 36" TV
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
