Question about Maytag Neptune MAH5500B Front Load Washer
Display often shows FL but is not overloaded
There seems to be no rhyme nor reason for FL....even unplugging the machine...sometimes that works, sometimes not. Any ideas? This is very frustrating.
  • 89 Answers
FL stands for Flood Lock.
this happens when the unit has not tripped the water level switch in a certain amount of time
check that inlet water valves are turned on.
aftarwards it would most likely be a pressure switch,
Posted on Jun 19, 2009
What does fL code mean on the wtw6400sw3 washing machine
In your case, when your washer shows LF it means: washer is taking to Long to Fill. And fL would not mean full or overload, because then it would say oL (OverLoad).
I advise you call and ask the company.
U.S.A.:1-800-253-1301.
Canada:1-800-807-6777.
Oct 04, 2012 | Washing Machines
I have the 7350 prodry carpet cleaner and it while cleaning a room today it completely shut off with no rhyme or reason.
It has a build in clog protector. Once the machine starts to overheat due to a clog, it should shut off to prevent burn out. Unplug the unit, Make sure there are no clogs, sometimes even the smallest clog does not seem major but remove them. Also, make sure cannesters are all connected proper and tight. Good luck!
Mar 26, 2011 | Bissell 7350 PROdry Upright Steam Cleaner
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso washing lights on the front panel will not light up.i push the choice i want then it reads FL and all it does is hum and beep.even when off it will beep and read FL.i will turn it...
Flood Condition:
Oct 15, 2009 | Kenmore Washing Machines
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Calypso Cycle Problem
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso stoped and FL flashes and will not cancel,
Flood Condition:
Feb 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
117 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
