Question about Swisher Mower 9016 24-inch Blade Fits Wb11524 Wb80024 Wb80024s
Replace the trans and drive belt on a swisher wb80024
Engine runs on my swisher 2560 but will not move, stopped while mowing
Drive belt may have broken or idler pulley could have malfunctioned or drive belt could have just came off alignment.
Sep 10, 2017 | Swisher Garden
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
Oct 24, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
Belt drive
I think that machine has one belt that runs everything the deck. If it does you should have a tent ion poorly release it and the belt will slacken up so you can pull the belt off. If the tent ion poorly is not on the deck then it will be under the machine just look for the poorly that puts tent ion on the belt. Let me I know how it goes good luck.
Jun 14, 2013 | Swisher 60" 26 Hp Zero Turn Radius Riding...
What size belt for my swisher 44" pull behind
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Jun 28, 2011 | Swisher 44 Iinch 11.5 Hp Trailmower...
I need a belt diagram for swisher t60 trail mower
Here's the manual for it - section 12 belt replacement, page 16. It goes over all pulleys except the idler - it goes under the idler pulley.
Aug 30, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Swisher Mower 9016 24-inch Blade Fits Wb11524 Wb80024 Wb80024s Logo
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
