Question about Saeco Magic Comfort Plus Espresso Machine
Blockage water to espresso - Saeco Magic Comfort Plus Espresso Machine
Just got a Jura x5 from a friend who has not used it in 3 years. Plugged in, set up, and display reads "system fills" but no water is released from the water reservoir. Machine makes a sound, like the...
Message :Fill System
Causes/Troubleshooting:
Leaks in the fluid system-localize the leaks and seal them.
Blockage in the fluid system, no water can be fed - Localize blockage and replace blocked components (valves, heater, tubes) if necessary.
Flow meter-count error - Open the floow meter by a quarter turn and clean it, replace if necessary.
Oct 01, 2013 | Jura Capresso Impressa Z5 Espresso/Coffee...
Ascaso dream is not pumping water
If you can hear the pump running, I would say you have some blockage in the line
Apr 12, 2013 | Ascaso Dream Espresso Machine
I have a Astoria Argenta and one of the groups is not working. If there is a blockage, how do i get to the problem.
basicaly all you can do is unplug machine, turn off the water and cool machine to cold. then take apart the group head working back to the boiler till you find the blockage.
Aug 31, 2011 | Astoria Argenta SAE-2 Espresso Machine
Flowmeter error on an Ambiente Espresso Machine for Dunkin Donuts
Flowmeter A restriction of water flow.. is the drink interupted when you see this message if so replace flowmeter.. if not look for the blockage of flow coffee in the inlet tube to brew group,, calcified hot water boiler inlet tube plugged pistons..
Sep 27, 2010 | Schaerer Siena Espresso Machine
My precious Gaggia Classic machine has developed a "fatal error". It will not pass water through the shower head. I have tried cleaning, re-priming to clear air block, several times over. The pump appears...
Remove the shower, then the 2 allen wrench screws for the diffuser, careful do not loose the spring ad valve seat that is above the diffuser, now turn machine on to see if water will come thru, if water flows, problem is either screen or diffuser blockage, if no water then you need a stronger descaler because blockage is in the boiler, at the solenoid or from the pump. Most likely in the boiler, if you have a boiler gasket go ahead and open the boiler to clear the blockage.
Jul 04, 2010 | Gaggia Classic Espresso Machine
Water does come out of espresso maker. comes out of wand though
Remove the portafilter and press brew button if water flows then problem is the grind if no water remove shower screen and make sure it is clean also press brew button without shower, if no water then the machine will have to opened to find the blockage.
Sep 13, 2009 | Breville BES400 Espresso Machine
Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Jul 11, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Grouphead not dispensing water
Remove the shower screen and press button to brew, if water flows the the holes in the screw/diffuser is blocked, if water does not flow then the blockage is at the solenoid or within the group head chamber. This problem I have notice when someone brewed without the shower and screw in place.
Jun 29, 2009 | La Marzocco Linea Series Group 3 Espresso...
Water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
Apr 11, 2009 | Nuova Simonelli JAZZ Espresso Machine
Saeco incanto
Do you get water?- If so, could be steam valve blockage somewhere and or steam boiler issue. Descale the machine first to see if this remedies the blockage.
May 08, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
21 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
