Question about Gateway T-6330U Notebook
Let our Experts solve your ''gateway laptop model 6330u wireless card switch not working dropped laptop card drivers ok'' Problem
  • 1 more comment
  • presley201 Jun 19, 2009
    it's the switch that's not turning on the wireless mode. I get internet connectiion when I connect the cat 5 line. How can I get this repaired? Is it something I can do? If I don't over solder?
    my zip code is 60440, you suggested that a solder poin on the main board is probably broken loose. H0w do I get that repaired?
    Gateway model t-6330u wireless card switch not working, dropped laptop. plug in option does work. Can you send schematics showing what is broken loose?
    Thank you for your comment. I just signed up for Fix ya 30 minutes ago, so if I affended you I apologize. I did not know that reposting reflected badly on you. I read my agreement and have repair service. I am following directions. Sorry for any ackward questioning.
  • Gateway Master
  • 13,433 Answers
Hi
So the laptop was dropped and now the wireless switch doesn't work anymore? the switch is in most laptops directly soldered to the mainboard. if the switch is damaged or broken it would need to be replaced by a professional, too much heat on the motherboard will separate and possibly ruin the whole laptop motherboard.
Did I get that correctly? its a switch and the wireless turns off and on from it, as far as I know you can't turn on the wireless if the switch is broken.
Posted on Jun 19, 2009
  • 1 more comment
  • Ekse Jun 19, 2009
    if you decide to replace the switch yourself, do it at your own risk, use a 25W solder iron or lower. if you heat the motherboard too much the layers may start to separate and after that if it goes too far the whole board will be ruined.
    I would recommend finding someone who has experience in soldering laptop motherboards without messing them up.
  • Ekse Jun 19, 2009
    Well, I don't appriciate being reposted. Hopefully someone else will provide you with valid advice, there are alot of useless "experts" on this website.
  • Ekse Jun 19, 2009
    not a problem on the repost, don't worry about it.
    So you do have warranty or repair service that you can get on the laptop?
    If you want to send me a reply / message use this link:
    http://www.fixya.com/PostComment.aspx?th...
    Or email me directly at nikoht@gmail.com
    Top Expert:
  • Gateway Master
  • 81,400 Answers
If u droppped the card then i strongly suggest you replace it, that is most likely the problem, u can also check the network connection by going to control panel and then click "Internet and network connections", if the connection is there you will see it in the window, you can click on it and select repair network connection and see if that helps.
Gateway mx3410 wireless card
You can download the wireless card and device drivers for your model Gateway laptop from this WEB site. Make sure you select your model laptop and the correct Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Feb 19, 2013 | Gateway MX3410 Notebook
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...
www.opensuse.org/
Dec 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Drivers for gateway t-6330u
Hi
click on this link and it should take you to the gateway website where you should be able to get your drivers
go up to support
http://www.gateway.com/
Feb 24, 2011 | Computers & Internet
Gateway T-6330u Laptop won't boot up
I would think that unfortunately the hard drive, is faulty. You will have to replace it.
Mar 08, 2010 | Gateway T-6330U Notebook
Wireless network capability to gateway t-6630u won't turn on?what should i do?
click on start then click on control panel then go to system then click on hardware then click on device manager then click on network adepter and see is there any red or yellow mark if it's there right click and click on left click hardware scan it will work or run the driver cd on the computer
Dec 17, 2009 | Gateway T-6330U Notebook
Reloaded the os on my gateway mx6436 and now it doesn't find the wireless card It was working earlier and the F2 function key shows it to be working
You have to install the driver for the LAN card, you should be able to get the driver from the gateway website driver and support
Nov 16, 2009 | Gateway MX6438 Notebook
The wireless is not working on my gateway laptop
Have you installed the wireless card driver?
If not then :-
You can download the drivers for your model Gateway laptop from this WEB site, make sure you select the correct XP or Vista drivers. Click on this link: -
Nov 15, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
HOW do I remove the keyboard on a Gateway Laptop Model T-6330U, I spilled juice on keypad and heard sizzling when I restarted, and monitor fadded out. An external monitor works fine, and computer boots up...
You could send the laptop in for repair but it could be quite pricey, it sounds like the LCD is toast. If your keypad still works using an external monitor then you won't have to replace that.
Sep 20, 2009 | Gateway T-6330U Notebook
No wireless driver on my gateway t-1625
find your wireless card manufacture n serial number inside your backward laptop casing. there sould be any informations about your wifi card. find it up n download the driver form official website. go googling...
Apr 09, 2009 | Gateway T-1625 Notebook
I just purchased a model T-6330U notebook from best buy.It is equiped with wireless internet access.I am useing a verizon fiber optics router,with wireless capabilities.I activated the wireless networking...
Have you installed all the softwares (drivers) that goes with your laptop? Some laptops have specific softwares that need to be installed to make the components (hardwares) work.
Nov 11, 2008 | Gateway Computers & Internet
Gateway T-6330U Notebook Logo
83 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
