Question about Boating
Will not start until starting fluid is sprayed into intake. then operation is normal
ronaldo_ross
  • 1056 Answers
SOURCE: My 1997 GMC Safari Van will not start when cold
Check for a bad temperature sensor. To check it, remove it first. Using an ohmmeter measure its resistance, which should decrease when dipped in hot water. If the the resistance remain high and doesnt change then you know it is bad, and you don't end up wasting money on buying one when it is still good.
Posted on Aug 12, 2009
  • 17 Answers
SOURCE: car won't start unless we spray starter fluid in
Adding a highly flammable fuel like ether shows all the other elements are in place to create ignition. Your problem is obviously related to your cars fuel system. Whether it is a pump that is not providing the fuel to your cars fuel injection system, or your fuel injector nozzles no working properly is a question that cannot be answered here. All I can do is point you in the right direction. Typically these days computer analysis is warranted to trouble shoot which sub-system of your fuel delivery system is malfunctioning.
I would highly recommend you describe your issue to a reputable garage capable of doing some system testing, and they should be able to quickly pinpoint where precisely your issue is.
Posted on Sep 12, 2009
SOURCE: recently I have had to spray starter fluid in the
my expediton started the other day and immediately shut down, it wont turn over. has a new air filter, 1/4 tank gas, new oil change. it started when we sprayed starting fluid but then shut off. what is wrong?
Posted on Feb 14, 2010
  • 7353 Answers
SOURCE: will not start. turns over when i spray starting
First you need to verify that the pump is getting power. Did you check the Inertia Switch? Power goes through that switch to the fuel pump. If the switch is good, and getting power,the fuel pump is most likely bad, the fuel tank must be lowered to replace the fuel pump.
Posted on May 25, 2010
jturcotte
  • 8560 Answers
SOURCE: 2001 MUSTANG CRANKS BUT WILL
check fuses 28 and 34. I don't have all the diagrams, but it may be that the pump or injectors use a different fuse for start versus run.
Posted on Oct 03, 2010
A slow start in my nissan micra k11 1998
I would keep a can of spray engine starting fluid on hand, when it won't start spray the fluid into the intake while a friend cranks the engine, if it starts you have found the issue, the fuel pump or fuel pump relay is defective.
Jun 24, 2016 | Nissan Cars & Trucks
91 Ford Explorer 4.0 V6 5 speed manual. The truck will not start unless gas or starting fluid is sprayed into the intake. once this is done the truck will start and run normally just as before the...
Is this car fuel injected? If so there shlould be a flow sensor somewhere on the intake . Many of the patrs stores will loan an OBDI or II and you could do a diagnosis on the engine. This should indicate a faulty flow sensor among other problems.
Lots of luck.
I have the same year, model and engine with Automatic tranny, This was the year the Explorer replaced he Bronco and there seems to be a bunch of prototype parts. I just replaced the headlight/turn signal multifunction switch for $185.00. :(
Not a lot of information about this year. But it is a fun car :)
Sep 23, 2013 | 1991 Ford Explorer
My Yamaha runs rough on one cylinder, unless you spray starting fluid in the intake, then it will smoth out and run great until you stop spraying.
If This Engine Has Rubber Boots Between Carb And Intake Port(Head) The Clamps May Be Loose Or The Rubber Boot May Be Cracked Or Permeated( Leaking Air, Lean Condition). Never Use Starting Fluid To Test It Will Wash Oil From The Cylinder Wall. Use WD-40 It Contains A lubricant.
Apr 15, 2013 | 1985 Yamaha XJ 700 X Maxim
1989 chevy 2.8l v6 MPFI injectors have no signal on the noid light. The car starts with starting fluid sprayed into intake and actually runs until starting fluid is consumed. if I place a rag in the intake...
look for a bad ground, you can try running a new ground from the battery to the body, i had an 89 corsica that would not fire until i ran the new ground wire.
Oct 01, 2012 | 1989 Chevrolet Corsica
Have to spray starter fluid in the intake to get to start. once started runs fine, why?
This sounds like a weak fuelpump, and take a while to build up pressure, the starting fluid get the engine running until the pump builds up pressure, i would have the fuel pressure tested and i think you will find that its bad. good day.
Jun 19, 2011 | 1996 Ford Explorer
Have a1998 astro van that wont start until I spray starting fluid in the throttle body, then starts up and runs fine until about two hours later I go to start it back up and it wont start again.PLEASE HELP...
The first thing you need to check is fuel pressure. This type of fuel system requires a minimum fuel pressure of 56 psi to start. Anything less, even as little as 1psi. And it will not start. It starts and runs when you add the starting fluid because the poppets (the mechanical injectors located at each cylinders intake runner) require less fuel pressure to operate when the intake is under vacuum.
This is a classic symptom of low fuel pressure. A new fuel pump is the typical fix for this problem. Don't skimp on quality if you do need a new fuel pump. They are not all the same.
May 24, 2011 | 1998 Chevrolet Astro
Engin runs fine at idle but stalls out at high idle and wont rev up.
Hi 5flash... Get an assistant and a can of starter fluid. Remove the air cleaner and spray some starter fluid into the air intake. Start it up and spray the starter fluid as you move it to high idle, repeat until it works properly. Joe
Thanks for choosing Fixya!
Feb 22, 2011 | Mantis 2-Cycle Tiller
My craftsman+Show thrower+model 247.888160 does not start
Make sure the ignition key is installed and the spark plug is connected. The off-most throttle position operates a switch similar to the ignition key. Both ground the ignition circuitry which shuts off the motor. If either are faulty the engine may not run. (In my situation, neither would not shut the engine off so I removed the spark plug wire - and it wouldn't start the next time until I reconnected it. Duh.)
A clogged fuel line may also cause this, and if it smells like gas the carburetor bowl drain may leak and let gas run out so it never gets to the cylinder. #32 in the image.craftsman-show-thrower-model-247-888160-zop2r3qcvvwbzivxvhxuu5lg-4-0.png
Dec 20, 2010 | Garden
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
