Question about Kenmore Microwave Ovens
My microwave is kenmore 3850wra014a-- voltage is 110V.. my home voltage is 220v..what is the spec for transformer
MicrowaveSvc
  • 9098 Answers
SOURCE: Voltage in home down when start microwave
Either the outlet for the microwave is not on its own breaker (which it always should be) or there is a loose screw connection or oxidation in the circuit breaker panel.
If the bad connection is on the neutral wire, this can create a dangerous condition.
You should measure (or have a pro measure) your voltage in various outlet s in the home.
If you have low voltage on some and high on others, you have a faulty neutral.
This can be serious. It should be checked.
Posted on Aug 12, 2008
SOURCE: Kenmore over the range microwave
buy
Posted on Sep 26, 2008
SOURCE: where can I get a HV transformer for Microwave?
I went on-line and found a site that gave answers to similar problems. I found that no power to the the control board usually meant a transformer issue. I checked the leads on the transformer (with a meeter) and found that it was shot. Now I need a replacement transformer, at a reasonable price, or else I will purchase a new Microwave.
Kenmore model 665.68682891
Posted on Mar 31, 2009
wiznet2000
  • 86 Answers
SOURCE: how can i repair my microwave oven with a model
Try to replace the ceramic fuse located inside. you have to open the cover first
Posted on Jun 23, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: my sca2000bww03 microwave has
It is a 220V oven and will not work with a 110VAC supply.
Posted on Dec 03, 2010
I have 110V AC, Sharp Household Microwave Oven, power transformer is damage. Is 220V AC transformer can be use as replacement?
NO. There should be a label on the part which has its part number, something like RTRN-A.......
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 01, 2017 | Sharp Microwave Ovens
Can a microwave be repaired?
Yes it is repairable, but if you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. If light and turntable works than low voltage circuit (220V or 110V) works well. In this case the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board. If light and turntable does not work than fault could be in power supply elements like: power supply cord, transformer, power board, fuse (glass or ceramic, ussualy 8A, 10A or 12A) on power board.
Dado
Oct 24, 2015 | Kenmore Microwave Ovens
Microwave runs but will not heat the food
If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well. Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board.
Dado
Feb 13, 2015 | Microwave Ovens
Kenmore 3850w
voltage in your is probably 120/240 just find an outlet that matches your plugs configuration and check with a voltmeter if unsure
Apr 21, 2014 | Kenmore Microwave Ovens
HOW TO USE CUSINEART GRIDDLER WITH 110v TO 220v
Get a step down transformer/converter. Grill consumes 1500watts of energy. Converts cost 200 dollars here at sim lim tower/square. Make sure get the correct watts, it is very important.
Apr 06, 2014 | Cuisinart Microwave Ovens
No power to my microwave
first check the mains power chord for continuity and open circuit.
if this is ok then check the input voltage .(either 110V/220V)
Check these and tell me .
Mar 27, 2014 | Whirlpool MT4078SKB / MT4078SKQ 700 Watts...
There's no high voltage ,thus no magnetron activity
check the ceramic fuse in the primary circuitry as it probably blew out when the primary connection arced and burned through
Mar 23, 2010 | Magic Chef MCD1110ST Microwave Oven
Will i need a separate 110 circuit????? cannot use the 220v leg??
I would contact a few electricians for their opinions. Appliances like microwaves and ranges, etc. should be on separate circuits / breakers due to the high currents they draw.
Dec 08, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
