Question about Cell Phones
Lg tv troubleshooting
LN575 How to remove the Store Demo.
How do i remove the 4 boxes that keep coming up at the lower left of the screen?
  1. go to main menu -
  2. select display -
  3. select advanced at the bottom of this screen -
  4. in this menu you can turn on/off the trumotion demo.
May 22, 2016 | LG 42LG50 42 in. LCD HDTV
Tip
How to remove store demo pop up
To remove store demo follow this steps:
1. Enter to menu
2. Setup
3. Plug and play
4. Insert pass code (default 0-0-0-0)
5. Follow instruction until store demo and home use appear.
6. Choose home use.
7. Finish.
on Mar 29, 2011 | Samsung UN46B7000 46 in. LCD TV
My tv model number is 60lb5900-uv how do I get it off of store demo
How To Take Your Tv Out Of "Demo Mode"
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMay 21, 2012 - There are 2 ways to take your tv out of demo mode. ... When the message, "Menu language, store demo, and time will be set", and then press ...
Samsung: LN46B650 is stuck in Store Demo mode - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI just bought a Samsung LN46B650 and it is stuck in Store Demo mode. ... If you do get prompted to choose between HOME or STORE mode (and you might), ... on the tvfor 10-15 sec(i did almost 30)...but the store demo mode wont turn off.
Samsung HDTV - Disable Store Demo Mode (UN46D6003 ...
? 0:39
https://www.youtube.com/watch?v=emPw3NkUuss
Nov 28, 2011 - Uploaded by SPSN
Jan 19, 2016 | Televison & Video
I auto tuned LG Full HD Tv 27 MA53 and it now shows store demo and I can only get one channel
Use the remote to enter the set up for tV. There will be a setting to change from RETAIL to HOME.
Feb 22, 2015 | LG Televison & Video
There is a number of pop ups onthe tv stations on the side and the top
It seems like your Tv is on demo mode go to the menu screen select option and search for tv mode turn it from store/demo mode to house mode also check that if demo in on to turn it off
hope i was helpfull
Jul 31, 2014 | LG Televison & Video
How to find settings on lg tv 32cs560
Press the Settings button on the remote or touch the Settings button on the front panel. You may download a copy of the manual from http://www.lg.com/us/support-product/lg-32CS560#
Jun 29, 2013 | LG 32cs560 32 1080p Lcd Tv 32cs560
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
How can you unlock a commercial 42" LG lcd tv to
1st-Go to the menu 2nd-Options menu 3rd-At the very bottom initial setting 4th-Select english as language and it should say store Demo or home use
May 06, 2011 | LG 42LC2D 42 in. LCD HDTV
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
