Question about Vacuums
Bissell proheat no suction
MI MAQUINA ES NUEVA PERO NO QUIERE ABSORBER EL AGUA NO SE QUE PASA NO LA ESTOY OPRANDO BIEN O TIENE DEFECTO ?
SOURCE: water suction
Here's what I did. On the top of the water bucket there is a red oval screen, remove and clean the screen and replace. Also, next to the screen is an oval opening which meets up with a black oval gasket on main unit. Inspect the gasket and replace if dry or cracking. Otherwise, if it looks good, reseat the gasket (it fits into some grooves). When you fill the bucket and put the the top on, put it in the machine and make sure it is making good contact against the gasket. This worked for me. I also found a repair manual for these units that could be helpful located at: http://www.bissell.com.au/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on May 24, 2007
  • 37 Answers
SOURCE: bissel proheat 2x main suction problems
on the top of your tank you have a divertor, did you switch this to the floor setting?
Posted on Sep 28, 2008
SOURCE: Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
Posted on May 13, 2010
heatman101
  • 43501 Answers
SOURCE: My bissell proheat 2x has
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum: I have a Bissell proheat 2x deepcleaner 9200 model...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
fkj
Posted on Sep 30, 2010
Will not stop when switched back to the vertical or ready (off) position it then pumps out all of its watter on the counter top.
su problema puede ser el interuptor que tiene la maquina en el mango para activar y desactivar el encendido debe ser revisado por expertos
Oct 05, 2010 | Vacuums
Bissell Proheat 1699 won't spray from main/min. suction
heatman101
kgj
Jul 27, 2010 | Bissell 1699 ProHeat Clear View Upright...
No suction on bissell proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Nov 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissel proheat has no suction
heatman101
Oct 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat no hose suction
heatman101
Jul 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
MY BISSELL PROHEAT WONT SUCTION
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell ProHeat 1699
There should be a black oblong gasket that sits between the edge of the noozle and the lip of the tank, If it is missing, then you will have to suction there. Also there should be a plastic red filter, mounted on the tank lid, covering the suction port, it it is clogged, then no suction.
Aug 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
