Battery removal to shiva p551-a5202 - Televison & Video
Toshiba P55t-A5202 bios
Go to web site and see if you can download a Cmos bios for the chip along with the program with which to do same. Those things are never guaranteed to work - glad I do not have your problem.
Sep 06, 2017 | Toshiba Computers & Internet
Remove battery p55t-a5202
after you turn it off, unplug the adapter, close the display and turn it over. You will want to have a small jeweler's flat blade screwdriver, or similar, to pry out the 14 small rubber plugs from the screw holes. Then you'll need a #1 Phillip's-head screwdriver to remove the 14 screws. Carefully separate the bottom cover. There you will see the battery. It is plugged into J6001. It is held in by 4 screws and some wires that are taped/dressed to it.
Feb 26, 2015 | Toshiba Satellite Computers & Internet
Clean heatsink on a toshiba p55t-a5202
usually canned air does a good job .
Feb 21, 2015 | Toshiba Computers & Internet
Toshiba satellite p55t-a5202 laptop hibernates then wont turn on
I have had the same problem with my toshiba p55t-a5202 from best buy took it in 2xs then was without a comp for weeks. The 3rd time I just took out 14 screws on bottom(do not loose them) carefully removed bottom cover (push in and up at sides to remove) then found battery. I followed the wires to the middle slightly larger white plug. Then took a very small screw diver and pushed down gently in the flat spot while pulling gently to disconnect the plug. The side lights went out. Then pluged it back in the same way I took it out. I put all screws back on the bottom cover. Pluged it back in and turned it on and whallaa! My lap top was working and I didn't have to be without it for weeks!! I like this comp but will NEVER buy another one with an internal battery. I guess til the next time it not responsive! Ugh! Goodluck!
Oct 07, 2013 | Toshiba Satellite L355D-S7813 Notebook
My toshiba satellite laptop hasnt been turning on for ages and charging doesnt work, its not even charging! What do I do!?
Hi friend, this could be due to bad battery. Just remove the battery and connect the power to the laptop and see whether it works. If it works without battery, then replace the battery.
Thanks,
Shiva
Dec 19, 2010 | Toshiba Computers & Internet
The computer turns on but nothing appears on the monitor. I've had a tech look at it and said he thought it was a bias problem and then adjusted the battery and it came on. Now it's back to the same...
Hi friend,
Power off the system completely, remove the battery and keep it aside. Now, check whether, the system works fine without battery. If it does, then, the issue is with the battery. In that case, just replace the battery.
Thanks,
Shiva
Dec 18, 2010 | HP Compaq Presario SR2027X (RK554AA#ABA)...
Code comes up as p 551 an p 420
i would replace the power steering pressure switch for the code p551. as far as the p0420 this is a rare code and indicates an 02 sensor out of range.. the second 02 sensor could be fouled up.. remove it and clean it also perform intake cleaning with carb cleaner...if still exist next try replacing second 02 sensor
Jan 04, 2010 | 2002 Chrysler PT Cruiser
Bios battery
Does the bios posting displays
Jan 01, 2008 | Intel Shiva LanRover Plus Modem
Lost lanrover d56 password
Do you have the Shiva Security Manager at Start > Programs > VPN link ? If not I can help you through it.
Aug 07, 2007 | Intel Shiva LanRover D56 Modem
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
