Question about SE Electronics SE2200A Professional Microphone
SE2200A- how to rewire?
Hi everyone, I dropped my SE2200A and the two cables at the top (red and black) came loose. I don't know where to re-solder them. Can anyone help? Thank you! Filippo
2 Suggested Answers
  • 12 Answers
SOURCE: frequency settings on se2200a
It is a pad..which is a switch that will 'reduce' sound level or volume which in a nutshell is useful for recording loud instruments..So switch to -10 db if placing the mic fairly close to say loud drum or horns..etc..
Posted on Mar 20, 2010
I HAVE A RV WITH AN ELECTRIC FIREPLACE, ITS A HEF26 FROM CFM CORP, DOES ANYONE KNOW WHERE THE RESET BUTTON IS? IT JUST STOPPED WORKING, NO BLOWN BREAKERS
Hi I HAD THE SAME PROBLEM. I TOOK THE electronic BOARD OUT AND FOUND that the main power relay (that's the big black square on the board with the black and red wire connected to the top of it.) solder joints were loose. I bought a cheap soldering gun and resoldered the relay connections at the bottom of the board............Works Fine now................FC
Jan 12, 2013 | Heating & Cooling
I have a 2001 xterra with one headlight that is not working, i have deteremined that there is a short somewhere in the line but not where i can get to it, I want to rewire it to the module on the other...
A short will blow fuses, you don't mention that. there is no "module". there is the headlamp switch and its directly wired to the headlamps. which headlight? hi and/or low beam? Low beam power is RED, for left, RED/BLACK for right, check for voltage on the black wire, there shouldn't be any. hi beams and low beams are on 2 different fuses.
Sep 21, 2011 | 2001 Nissan Xterra
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
My conair infinityhair straightener just stopped heating up.it turns on but it dosent heat up.
This is a job for one with a multimeter and soldering iron. Remove the temperature knob and the plate below that. It will expose the inside of the top half of the Straightener. You will see two set of red and black wires soldered to a green circuit board. See if the soldering are intact and no wire has come loose . Now unsolder the red wires ( please note which wire goes where ). With the multimeter in the Ohms range ( X100 ) touch the probes on the red and black wires each and check for continuity. The red and black wires are two ends of the ceramic heaters. If they have failed , replace .
Mar 07, 2011 | Conair Professional Ceramic Hair...
I dont know how to rewire the back of my dean evo xm? i tried to fix the faulty input so i thought the wires were faulty so i tried to rewire it and i dont know where everything goes now. theres red yellow...
It is rare that wires would be faulty. Soldering can be, but not the wires usually.<br /> <br /> Common problems are broken jacks or pots that are broken or shorting to the paint in the cavity.<br /> <br /> If you have things unwired now, the best thing is to find an appropriate circuit here and wire it like that:<br /> <br /> <a href="http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/">http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/</a>
Aug 28, 2010 | Dean Evo Xm Electric Guitar
Wires came loose of control unit from circuit board do you know what order they should be soldered back green white and yellow wires are still connected but I don't know where/which terminal to...
maybe we can help each other out with the questioni have my white black and red still connected but the purple blue yellow green and brown cables are un soldered if u look at the transmitter with the buttons on the bottom and the screen at the top the wires should be on your right there should be nine spots strating from the bottom to upward skip 1 next one should be white then skip one next should be red then next one is black and then thats all i have hope we can help each other
May 15, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
I need to know how to rewire the ignition system
Hi and welcome to FixYa,
On your requirement to "...rewire the ignition system..." of an XS650, below basic ignitor wiring scheme maybe of reference:
  • white / red - from pick up;
  • white / green - from pick up;
  • black / white - from pick up;
  • orange - to ignition coil;
  • red / white - IGN + 12 from engine stop switch ;
  • black - ground;
Good luck and thank you for asking FixYa.
Nov 14, 2009 | 1980 Yamaha XS 650 G
SE2200a, No input signal
If my comment helped you find this problem, could you respond to the fixya questionnaire accordingly?
thanks...
Charlie
Apr 20, 2009 | SE Electronics SE2200A Professional...
SE Electronics SE2200A Professional Microphone Logo
37 people viewed this question
Top SE Electronics Audio Players & Recorders Experts
Willem.
Willem.
Tom Chichester
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
