Question about Dishwashers
Swan Essential Dishwasher SDW7030W the snowflake symbol is lit what does this mean
I've just been given this model and when plumbed in the snow flake symbol is lit up can anyone please tell me what this means thanks
  • 351 Answers
SOURCE: Asho D1976 Dishwasher, what do the SYMBOLS mean??!!
power button far left then heavy wash, normal ,light,and quick i think you also have economy and temp bottons.if you live in aust call 1300 00 2756 or goto www.asko.com.au hope this helps
Posted on Mar 12, 2008
SOURCE: Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
Posted on Jun 10, 2008
SOURCE: Symbols on the Dishwasher
The circle that looks like a sunny side up egg? That's the super hot sanitary rinse.. the other symbols simply mean lots of plates only, plates with glasses, or the short section means rinse.
Posted on Jun 18, 2008
SOURCE: Whirlpool ADG7540 integrated dishwasher -
my integrated whirlpool dishwasher is not spraying from the top but is letting water in from the bottom and draining okay
Posted on Oct 14, 2009
Macmarkus
  • 2605 Answers
SOURCE: Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Posted on Jul 08, 2010
What does the blue snow flake symbol mean on the display
A blue snow flake normally indicates cooling mode
Dec 23, 2015 | Heating & Cooling
Snowflake symbol light is on
It might be showing that the rinse aid level is low. Top it up and see if the snow flake light turns off.
Apr 20, 2014 | Dishwashers
1998 Cadillac Catera-what is the snow flake symbol on the console? and what does tcs button on console stand for? 2 defrost buttons-one is square, one is rounded, what is each for Thank You!
Snowflake is A/C. TCS is the traction control system. The defrost button that is rounded on the bottom of the pic is for the front window. The one with the square bottom is for the rear window.
Feb 22, 2011 | 1998 Cadillac Catera
I have lost my manual for my bio tech plus air con. my air doesnt seem to be cold at all, not sure if i have right setting, on the remote there is a sun, snowflake auto and i think a raindrop, which should...
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Feb 01, 2011 | Heating & Cooling
The snow flake on the dash is it a warning light
There is no snowflake on the instrument cluster if that is where you see the light. there is a gear (circular) with an ! in the middle. If that is on, you have an issue and may be in emergency cooling mode to rpevent engine overheating damage.
Need a better description of symbol and where exactly it is.
Also, check your coolant level.
U S Focus or Europe?
Nov 26, 2010 | 2001 Ford Focus
Swan Essentials dishwasher in white SDW7030W instructions
My Swan Dishwasher defaults to Intensive and keeps beeping, It will not start, can anybody help me please The model number is SDW7030W. Thanks
Sep 10, 2010 | Dishwashers
What is the lit snowflake icon mean
the snow flake means that freezing conditions my exist out side
Dec 06, 2009 | 1999 Mercury Cougar
It makes snow flakes. freezer door will not seal
These snowflakes that you mention are formed by moisture entering the freezer compartment,Even if the seal appears to be doing the job just the fact that you mention "snowflakes" tells me that the seal is not doing it's job.Replace the door gasket and that should fix the problem.
Sep 20, 2009 | Refrigerators
I got a 2002 mercury cougar and there is a light that turns on an off once in a while it's the second 1 next to the wrench it looks like a snow flake what dos it mean
The yellow/orange snowflake means its between 42 and 33 degrees and the red snowflake means it's 32 degrees or below (fahrenheit).
Jan 28, 2009 | 2002 Mercury Cougar
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
Owen Barnes
