Question about Kenmore Elite Oasis 27052 Top Load Washer
The dreaded LF code
MY KENMORE ELITE OASIS WILL NOT FILL UP AT ALL. I KEEP GETTING LF CODE(LONG FILL). SEARS SERVICE TECH SAID THE PROBLEM WAS THE WATER INLET VALVE AND CHARGED ME $270 DOLLARS WITHOUT EVEN TESTING THE MACHINE. I THINK THEY KNOW THIS VALVE IS DEFECTIVE. I WILL NEVER BUY SEARS PRODUCTS AGAIN.
  • 6,784 Answers
HI, there is not a defect notice or recall on this particular unit but, we get a lot of complaints about this specific issue concerning the LF code on a frequent basis. this issue dose concern the inlet valve.
The replacement will work better than the factory installed piece. This is basically a blind defect.(defective factory part).
Posted on Jun 22, 2009
What is the LF code on my kenmore elite oasis
The LF code stands for long fill.. I would suspect a water inlet solenoid valve as the most likely suspect. It may be the hot or the cold valve. If the valve does not completely open the time to fill your machine takes too long. You can't replace just the one valve because the part contains all of the water inlet valves. That of course jacks up the cost but what can you do.
Jun 29, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
What does the code LF stand for? It keeps stopping half way through the wash cycle and flashes this code.
LF is for long fill.
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Check the following:
? Is water supply connected and turned on?
? Are hose screens plugged?
? Is water entering the tub?
If all these are good and water is going in fast (both hot and cold) you may need a service company to come out and take a look
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What do I need to do to fix the Lf code problem on my oasis washer?
Following is the LF troubleshooting response from the Whirlpool Cabrio
Service Manual. The Cabrio is the same as the Kenmore Oasis.
“LF” (Washer is taking too long to fill)
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Are both water faucets turned on?
Is the drain hose sticking too far into the
standpipe (siphoning)?
Is the pressure transducer hose kinked or
dislodged?
Press PAUSE/CANCEL to clear display.
It takes a while to load but following is the manual in PDF format.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Dec 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer LF code sears kenmore 80 series
It means that your machine is taking longer then a specified time (~10 Mins) to fill!! Check your water pressure, the water valves, the little filters in the hose, where it screws into the water and/or machine. Good Luck
Aug 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Elite Oasis HE top loader washer; It will start but gives me an LF error.
this is a fault in the water valve control, "LF" means Long fill (fill time exceeeded), so u will need to have the sears guy out to sort this problem out. are the water valves on the wall turned on all the way?
Jul 15, 2009 | Kenmore Washing Machines
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LF error code
I had the same problem this weekend. Sears said they would have to send someone to fix it. Now I have to wait til Wednesday. It better be fixed then! It's only a month old machine, and I'm livid.
Jan 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
531 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
