Question about Ryobi 10 in. 30 cc Gas 4-Cycle Cultivator RY64400A
Oil leak from ry64400
Oil leaks from my ryobi ry64400 model
3 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: RYOBI ECS-1835/ECS-2040 leaking oil when
Hi, the question i have to ask is this ,, When last did you service the Engine??
ENGINE VACUUM LEAK DETECTION
Okay, now that we have covered what a vacuum leaks do, how do you find components that leak vacuum? One way is to visually inspect all the vacuum hoses and connections. Look for disconnected, loose or cracked hoses, broken fittings, etc. Hey, you might get lucky and find the problem in a few minutes, or you might waste half the day trying to find the mysterious leak. Vacuum leaks are often the elusive needle in a haystack. And if it is not a hose leaking vacuum but something else such as a gasket, worn throttle shaft, injector O-rings, etc., you may never find it using this technique.
A faster technique for finding intake manifold vacuum leaks is to get a bottle of propane and attach a length of rubber hose to the gas valve. Open the valve so you have a steady flow of gas. Then hold the hose near suspected leak points while the engine is idling. If there is a leak, propane will be siphoned in through the leak. The resulting "correction" in the engine's air/fuel ratio should cause a noticeable change in idle speed and/or smoothness (Note: on engines with computerized idle speed control, disconnect the idle speed control motor first).
Aerosol carburetor cleaner can also be used the same way. CAUTION: Solvent is extremely flammable, so do not smoke or use it if there are any sparks in the vicinity (arcing plug wires, for example). Spray the solvent on suspected leak points while the engine is idling. If there is a leak, the solvent will be drawn into the engine and have the same effect as the propane. The idle speed will suddenly change and smooth out.
TIP: If you have a scan tool, look at the Short Term Fuel Trim (STFT) value while you are using carb cleaner or propane to check suspected vacuum leak points. If there is a leak and some of the cleaner or propane is sucked in through the leak, you will see a momentary drop in the STFT reading. This confirms you have found a leak (keep checking because there may be multiple leaks!).
USING SMOKE TO FIND ENGINE VACUUM LEAKS
smoke leak detection machine A much safer technique is to use a smoke machine. These machines feed artificial smoke into the intake manifold, The smoke may also be mixed with an ultraviolet dye to make leaks easier to see. You then look for smoke seeping out of hoses, gaskets or cracks in the manifold and/or use a UV light to find the leak. This type of equipment is often needed to find small air leaks in the EVAP (evaporative emissions) control system. Smoke machines can cost $600 to $2000 or more depending on the model and features, so they are primarily for use by professional technicians.
Posted on Apr 21, 2011
SOURCE: When in operation the Ryobi S430 string trimmer
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Posted on Mar 26, 2012
Ryobi ry64400 will not start?
  • Does it have spark?
  • Does it have compression?
  • Is fuel getting into the cylinder?
    More information required. Thank you
May 23, 2016 | Ryobi 10 in. 30 cc Gas 4-Cycle Cultivator...
Battery leaks oil while using or charging, why?
The battery does not contain any "oil", and should not be leaking any fluid whatsoever. Since it is doing so during use or charging, it points to leakage caused by slight thermal expansion under load. This is bad, as these are Li+ cells. If you are sure the leakage is coming from the battery, stop using it, seal it in a safe container, and dispose of the battery properly. To verify it is the battery, check and see if another (NEW) battery has this same "issue" under your normal usage.
Sep 02, 2015 | Drills
Ryobi rpt 3000 manual
over filled? http://manuals.club/document_order_init.php?search=RYOBI%20RPT-3000&doctype=1
Apr 22, 2014 | Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a Ryobi Cultivator, won't run. New spark plug - RZ7C. What is proper gap for plug?? thanks ront
The correct gap according to my RY64400 operators manual is .025 and the torque is 170-190 inch lbs. The spark plug is NGK CMR7A or Champion RZ7C.
Jul 27, 2010 | Ryobi Cultivator
How do I remove and replace a leaking primer bulb on a ryobi 31cc trimmer
http://odref.com/pdf/Ryobi/
see if you can find it here, since you didn't say which model you have....
Apr 01, 2010 | Ryobi Garden
Changing pump oil on ryobi pressure washer model ry80030 guy oil leaking out of breather on pump do I also need to change seals and if so how do I do this
I've worked on several of these so-called throwaway washers. They all failed from lack of oil. I managed to 'save' one and drilled and tapped a hole to add/ check oil.
Oct 23, 2009 | Karcher 2500 PSI Pressure Washer
Gas tank leaks on a 410r how do we take it off.
remove the screws holding the recoil cover off I would think and go here for parts and use your model numbers to find your unit.
www.ereplacementparts.com/ryobi-tiller-parts-c-7931_15702.html
Jul 01, 2009 | Ryobi Cultivator
Ryobi 10 in. 30 cc Gas 4-Cycle Cultivator RY64400A Logo
19 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
