Question about Microwave Ovens
CHANGE FUSE how to change a fuse in Panasonic Genius Premier microwave oven
MicrowaveSvc
  • 9085 Answers
SOURCE: Changing a fuse
First unplug the oven from the wall outlet.
Remove the two screws in top of the grille running across the top.
Rotate the grille forward and out and remove it.
There will be a metal grate at the right. See a photo here.
Now you can access the fuse.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: panasonic genius premier 1000w microwave -
The first step is to unplug the oven before changing bulbs!
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can usually download your Panasonic owner's manual here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 06, 2009
  • 18 Answers
SOURCE: Have no power on my Panasonic Genius microwave.
yes there is a fuse, it is behind the contol panel be sure to un plug
Posted on Jul 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: I need to change the fuse in my Panasonic
underneath the outer cover
Posted on Sep 26, 2009
heatman101
  • 43501 Answers
SOURCE: I've got a panasonic microwave genius NNS562BF
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Posted on Apr 02, 2011
No power to my Panasonic microwave
assuming u have pwr to the plug - and nothing lights up = it is probably a bad transformer - open thermal fuse.
WHICH was probably caused by a shorted mag, which means junk.
Feb 02, 2016 | Panasonic Genius Prestige Inverter...
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
My Panasonic microwave, Dimension4, The Genius, will not keep running after start button is pushed. It runs for only two or three seconds.
There is a thermal fuse that monitors heat from the magnetron, sometimes becomes defective, the magnetron "heats food" filiment will open on occassion, if the exhaust fan is not running microwave will shutdown.
Mar 09, 2012 | Panasonic Microwave Ovens
I have a National Panasonic Genius microwave that doesn't work the last four days. It won't heat, defrost, microwave or cook.Worked fine one day. Next didn't. All I had done was change the temp from high...
That fault is a little tricky. Need to check if you are getting voltage onto primary of transformer. If you are, the problem is almost certainly the magnatron which has gone open circuit. If and when you replace it, change the cap and HVdiode. Wont be sorry if you do. If no voltage there , your board is faulty. replace it.
Sep 15, 2009 | Panasonic NN-H275 Microwave Oven
Microwave stuck in demo mode
try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
My panasonic microwave [genius] has no power,after a power outage
Remove the cover (5 screws on rear and pull away from front) and replace the fuse at right side rear. (15amp 125v)
May 14, 2009 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
