Question about Garden
2001 polaris sportsman 500 ho one front wheel won't pull
SOURCE: ATV RUNS BARELY SOUNDS LIKE IT IS EXHAUSTING BACK THROUGH CARB
Check the cam shaft. The exhaust lob is the weak spot. They will wear down to nothing.
Posted on May 17, 2009
SOURCE: 2001 Polaris sportsman 500 magnum 4x4, speedo dont work
I'm not sure but it might be the sensor on the right front wheel disk
Posted on Sep 05, 2009
SOURCE: Can i get a wiring diagram for a 2004 polaris
having same prob with my preditor 500 any advice
Posted on Mar 28, 2010
SOURCE: Service manual for a 2006 500 Polaris Sportsman HO
I have a 2006 Sportstman 500HO ATV, EFI. Sometimes it will run 100% correct, other times it will start, idle fine but then when giving it throttle will will start to surge almost like it's hitting a rev limited. Sometimes it will backfire and stall. I already replaced fuel filter, flushed the fuel lines and gave it fresh gas and installed a new spark plug, but no good. I also checked the throttle switch and it's not making contact to stall it. I download the service manaul and tested each sensor and they tested fine which is probablt why I get no check engine light.
This ATV is mainly used to plow snow in my driveway, no salt. It's used around my property but very lightly. It's still as clean as it was when I bought it and it doesn't have but about 40 hours on it.
Polaris 500 HO EFI 4x4 ATV: Vin# 4XAMH50A56B707664 purchased 6-8-2006
gtopercy@comcast.net
Posted on Jul 15, 2010
SOURCE: polaris 2005 sportsman 500 H.O. service manual
Downloaded this last week....its the factory service manual ($3.99)
http://www.tradebit.com/filedetail.php/6901881-download-now-polaris-sportsman-500-2005-05
Posted on Aug 10, 2010
How do I replace a starter on a 2004 500 Polaris ATP
Search Results
Polaris Sportsman 500 ATV Starter Replacement - YouTube
? 12:50
https://www.youtube.com/watch?v=048ze6spX3k Apr 17, 2013 - Uploaded by mossman381
Replacing the starter on the 2000 Polaris Sportsman 500. Doing some checks before to make sure the ...
Polaris 500 Sportsman Starter Replacement - YouTube
? 4:28
https://www.youtube.com/watch?v=LSY5ffkQnZM Aug 24, 2014 - Uploaded by Cruiser Mac
Putting a new starter on my 500 Sportsman and doing a couple of other things while I am at it.
DIY How to Replace a Polaris Sportsman ATV Starter Motor No Clutch ...
? 13:57
https://www.youtube.com/watch?v=sA5f03Io8M0 Jun 28, 2015 - Uploaded by Mark Jenkins
... of replacing a starter motor on a 2003 Polaris Sportsman 500 H.O. The ... Hey Mark I just got a 2004 500 ho ... replace starter on 2004 500 Polaris ATP Google Search
Jul 02, 2017 | ATVs
2013 sportsman 500 gas running out the carburetor bowl from bottom. plastic tube to the ground. is the needle seat stuck?
Hi, Christopher and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2012 500 ho leaking gas from carb overflow tube
Polaris fuel leak repair
Polaris 2007 Sportsman 500 EF Service Manual
2013 Polaris SPORTSMAN 500 HO A13MH50AJ AQ AX AZ OEM Parts
Polaris Sportsman 500 HO Owner Manual
Jan 15, 2017 | GAS Motorcycles
Just bought this bike had no manuals with it I need to know about checking and changing oil
PDF]Sportsman 400 H.O. Sportsman 500 H.O. - Polaris
cdn.polarisindustries.com/polaris/.../parts-manuals/9923420r01_lo_res.p...
... parts and acces- sories, available through our online store at www.purepolaris.com. Have ... 2012 SPORTSMAN 400/500 HO Owner's Manual. P/N 9923420 ...
Polaris Sportsman 500 HO Owner's Manual - ManualsLib
www.manualslib.com > ... > Offroad Vehicle > Sportsman 500 H.O.
View and Download Polaris Sportsman 500 HO owner's manual online. PolarisIndustries All-Terrain Vehicles Owner's Manual. Sportsman 500 HO Offroad ...
2011 Sportsman 400/500 Service Manual - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Apr 11, 2011 - Indy Red 2011 Sportsman 500 H.O. -Polaris rear rack extender -Ricochet a-arm guards -Polaris fender bag -Koplin hand guards w/mirrors Owners, Service, and Parts Manuals
Sep 14, 2012
2005 Polaris 500 H.O. ATP service manual
Aug 12, 2011
Service manuals
Nov 29, 2010
Service Manual
Sep 23, 2010
More results from www.polarisatvforums.com
Dec 21, 2015 | Polaris 2011 Sportsman 500 H.O
Have a 2004 polaris ATP 500 when turning there's a clunking noise I changed wheel bearings and noise still there ! Checked u joints not really a lot of play in them!
2011 Sportsman 500 Trans Clunk - ATVConnection.com ATV Enthusiast ...
atvconnection.com/.../polaris/343211-2011-sportsman-500-trans-clunk.h...
Mar 21, 2012 - It is really noticeable when wheel is turned when you get on the gas from a. ... 2011 Sportsman 500 Trans Clunk ... You have to figure from the motor to the clutches,then to the transmission,then to the drive shafts,there is going ... 1999 Sportsman 500,slight clunk from dead stop
Feb 28, 2015
Clunk or pop in the steering on an 07 Sportsman 500 ...
Aug 8, 2008
500 HO, rear end noise
Apr 29, 2006
clunking noise on scrambler 500...
Jan 31, 2000
More results from atvconnection.com
Sep 25, 2015 | Cars & Trucks
Why will the cooling fan on my 500 sportsman not turn on .?
I have a 2001 polaris sportsman 500 H.O. I have replaced the fan and the thermial fan switch,and checked the thermostat. Everything is either new or works there are no bubles in the coolant when its running I am running out of opptions . If I unplug the thermal fan switch and plug a jumper wire in the fan will run. I thought the new switch was bad and I tested it and it is good
Sep 13, 2014 | Polaris 2004 Sportsman 500 H.O
2011 polaris 500 sportsman ho ...going down hill it free wheels is this normal ?
Yes this is normal for the 2011 Sportsman 500. The 500 does not have a one way bearing in the clutch acting like an engine brake as do the previous years. Polaris removed this option for the 500 sportsman in 2009. If you were to own a 550 it would not free wheel down a hill.
Aug 14, 2011 | Polaris ATV
4 wheel drive goes on and off
you ever change the hub fluid?
Jul 17, 2017 | Polaris ATV
May 08, 2009 | Polaris ATV
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
