Question about JVC KW-AV61BT
How to install jvc ks-u30
Where plug in ks-u30
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
Is the JVC CH -X400 compatible with the KS-FX222E?
Hello
The devices you specified here; JVC-CH-X400 and JVC KS-FX222E are non-compactable.
May 26, 2011 | JVC CH-X400 12-Disc CD Changer
I'm trying to install a JVC cassette receiver
Try checking here for wire color codes to coincide with deck.
http://www.the12volt.com/installbay/stereodetail/159.html
May 08, 2011 | JVC KS-RT320
Wiring diagram for jvc model no ks-fx460r
http://books.jvc.com/booklist.asp?Model=+ks-fx460r this should take you to the down loadable manual for that head unit.
Jan 12, 2010 | Car Audio & Video
JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Sep 18, 2009 | Car Audio & Video
KS-U58 JVC Input Adapter Cable
Just installed a 'generic' KS-U57 (same as the KS-U58, but terminates in a RCA, $7 on ebay) that has the same black box--except I cracked the black box open and found that it is empty (only contains soldered connections). I imagine that the authentic JVC is the same.
I have a noise problem (engine static), but it is because my mp3 player is charged by the cigarette lighter--unplugging it eliminates the noise, so as far as I can tell, there is no need for a noise filter inside the KS-U57.
Dec 04, 2008 | JVC Ks-U58 Input Adapter To Stereo Mini...
Lost the conector jvc ks f 150
Go to JVC website and type in your Model # and get the Installation/Connection Manual for free. This installation guide includes troubleshooting, electrical connections, and adding other equipment. Hope this is helpful just printed me a copy.
Nov 16, 2008 | JVC KS-F150 Cassette Player
Wiring Harness for JVC KS-R127
I can uually find those on ebay for a few bucks. You will need to count the number of pins then go shipping.... Also look for a seller called cali car stereo if they dont have it listed they probhably have it at thier store..
Sep 08, 2007 | JVC KS-R127
JVC KW-AV61BT Logo
Top JVC Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a JVC Electrical Supply Expert? Answer questions, earn points and help others
