Question about Soyo DYLT032D 32 in. LCD Television
Same problem same exact problem as u said, first started with the remote not working and now it just says no sync...its not just your tv
The problem is the capacitors on the power supply board. There are two of them, the rating is 220uf - 250v - 105C (M). The back side of the capacitor says V9A PET. You need to remove the board, make sure the capacitor is drained, (you can do this by placing a screwdriver across the posts) Use a soldering iron and remove the capacitors. The only place that has replacement parts is at www.mouser.com, Install them, make sure the polarity is correct, re-solder them back into place. Re-connect the board and it should power back up correctly. Good Luck. Steve
Posted on Jul 27, 2009
Will a Samsung AA59-00482A remote work with my Samsung PN50C450B1D plasma TV?
all samsung remotes work for each other only diffrence some keys on remote may not there but for menu and vol channel all function works once its a tv remote
Apr 28, 2014 | Samsung Televison & Video
When I go from "watching
My guess is that if it was working fine before and now it's not, some interference may have occured so the remote isn't in sync with the devices (for example, someone walked between the remote and the TV so the step is out of sync. To fix the problem, use the help feature on your Harmony One.
On the remote, press the 1. Help button.
Answer the questions on the Harmony One's screen by selecting 2. Yes or No.
Based on your answers, the Harmony One re-sends the necessary commands to synchronize with your devices.
When you're done with this process, the Harmony One will be "in sync" with your devices.
If this doesn't work, I would reconnect your Harmony one to your PC and start from scratch programming it again.
Nov 04, 2010 | Logitech Harmony One Advanced Universal...
Need code to re sync to tv
The Harmony remote does not use codes. In order to get the remote to work with your TV, you will need to add the TV to your remote in the software. You can download the software at http://logitech.com/myhermony.
Once you are logged in to the software, click 'Add Device' and enter the make and model number of your TV. When the TV is added, click 'Update Remote.'
Jun 05, 2010 | Logitech Harmony 890 LCD Remote Control
I lost my original remote for my toshiba tv model MW20F51 and found a toshiba wc-sb2 remote. is there any code i can use to sync them
No.Might some functions work, because they are both toshiba tv.Try website 1-800-Remotes Factory Original.Get the sanme exact remote or very simular.
Feb 04, 2010 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
I am trying to sync my sansui tv with my magnavox dvd/vcr combo. I can't figure out what channel the sansui needs to be on to play a dvd. The input button on remote is not working.
Tries buy a new remote this website have a exact or very close to the Original remotes.1-800-Remotes Factory Original.Tries channnel 3 only or 4 only functional for video equipments.
Sep 29, 2009 | Sansui DTV2760 27" TV
I synced it to the tv but I dont know how to sync it to the xbox
You shouldn't need to sync it to your x-box.
By clicking on the TV button it will change from your TV to the XBox.
Jul 26, 2009 | Microsoft Xbox 360 Universal Media Remote
Syncing the remote to the TV ?
Nevermind, just saw it was RCA in the title :p
This ought to cover you.
http://www.thompsontv.com/rcarc.html
May 26, 2009 | RCA Universal Remote Control
I cant sync my remote
u need to press both not at the same exact time but in the same few second , this is the only way to do it
Feb 17, 2009 | Microsoft Xbox 360 Console
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Soyo DYLT032D 32 in. LCD Television Logo
387 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Marvin
Marvin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
