Question about Oreck Magnesium Upright Vacuum
Oreck magnesium won't turn on - Oreck Magnesium Upright Vacuum
  • Alex Tworkowski Aug 22, 2016
    Had the same problem. Found out it was actually the button on the handle. Just works if you press in the lower left corner. Need to look into how to fix it.
  • Oreck Master
  • 932 Answers
Could be that you need a new battery in the handle. It takes a 2032 button type battery.
Posted on May 16, 2015
2 Suggested Answers
  • 2992 Answers
SOURCE: Have a brand new oreck magnesium ... Why would the vacumn on about the 2 nd or 3rd sweep come up off carpet and floors as if it is popping a wheelie?
Brand new? Warranty should still be in effect. I'd persue that route.
Posted on Apr 10, 2015
Hi I have an Oreck lw100 magnesium SP and it turns on for a second and then turns right off what do you think that could be thank you
It can be something stuck in roller or fan housing and it is turning off to protect the motor.
Jul 24, 2016 | Oreck Vacuums
When i press the wreck magnesium power button the unit starts but turns off after ten seconds. What the problem as the light continues to flash.
You could have a couple of problems. 1, you could have a broken belt, 2, you could have a bad sensor, or 3, you could have a bad pc board. The Magnesium has a sensor that detects whether or not the brush is turning. A quick way to check would be turn the vacuum over and turn it on, if the brush does not turn in those 10 seconds, you have a broken belt. If it does turn, I would suggest taking it to an Oreck repair store because it may still be under warranty and the sensor or pc board may still be covered under warranty. Hope this helps!
Mar 02, 2015 | Oreck Magnesium Upright Vacuum
How do I change the belt on an Oreck Magnesium LW100?
Lori, I work at an Oreck store on the weekends and we have a special tool that we use to open up the side where you have the belt. Before we got the tool, we just used a needle nose plier and put the two points into a couple of the dimples on the hub for the two large wheels. The side that you need to take off is the side that has the little filter on the inside of the frame. By the way, you should clean that filter off occasionally as well. If you look on the side of the grey hub you will see a pictogram of two different padlocks, one locked and the other one un-locked. You will also see a pictogram of an arrow pointing to the locked padlock and you will need to use the pliers to turn the hub till it points to the un-locked padlock. You can then pull the side housing off and that will expose your belt. You may need to take off the brush plate as well so that it is easier to put your new belt on. Two screws is all that holds that plate in place. Take them out and lift towards the front of the machine. I usually find it easier to put the belt on the brush pulley first and then walk the belt around the motor shaft. Re-assembly is just a matter of reversing the steps you did to take it apart. Hope this helps!
Feb 04, 2015 | Oreck LW100 Magnesium Upright Vacuum
How do I reset my oreck vacuum cleaner
If you are talking about the Oreck Magnesium vacuum, press the start button and hold it for about 15 seconds. Beyond that, most Oreck vacuums do not have any reset buttons.
Aug 06, 2014 | Oreck Vacuums
How to more easily vacum plush carpet with oreck XL vacum
The only Oreck vacuum cleaners that are rated for plush carpets are the two Magnesium models.
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
How do you change the battery in an oreck magnesium vacuum cleaner
At the back of the handle is the battery compartment, There is a simple turn knob to take the cap off to get to the battery. It takes a 2032 button battery. Hope this helps!
May 03, 2014 | Oreck Magnesium Upright Vacuum
Oreck magnesium keeps shutting off
Need to check your brush roller to see if it is spinning. Turn the vacuum over and turn it on. If the brush spins before it shuts off, you may need to check the bearings to see if any strings or hair has built up around the brush bearing shafts and is causing the brush to spin slower. If the brush does not spin, you have a broken belt and you will need to replace it. The Magnesium has a sensor that looks for the brush to spin at a certain speed and if it does not, it will shut down. Hope this helps!
Apr 12, 2014 | Oreck Vacuums
Oreck Magnesium Upright Vacuum Logo
1,128 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
