Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
What is average life of lamp - Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
    Problem Solver:
  • 6 Answers
Average 750 - 5000 hours depending on the bulb
Posted on Apr 22, 2014
Sony tv kdf6oxs955 lamp red light came on,tv not turning on ,screen is black,whats the solution
If lamp light is on remove lamp and inspect it to see it is not shattered inside.
Life on these lamps is 2000 hours or 2 years average.
Suspects are Lamp or Lamp Ballast that drives it in that order.
May 31, 2012 | Televison & Video
No screen and clicking sound
This set and the one before it (50lc13) had so many problems the latter was recalled and all were exchanged.
Someone would have to open set and check power supply first--set is not real easy to work on.
The recall involved issues where the sets were eating lamps up alive--very short lamp life---solution at first was to rebuild/replace the Ballast which drives the lamp.
Average life should be 2 years or 2,000 hours on that lamp.
May 25, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Lamp button flashes on and off
Suspect set has a bad lamp---light is there to indicate lamp or something associated with it has failed.
Lamp life varies but is usually 2,000 hours or 2 years average use.
May 02, 2012 | JVC HD-61G787 61" Television
62MX195 screen goes momentarily black a few times per minute
may or may not be lamp: lamp has a average life of 2,000 hours which is about 2 years for most people.
Apr 18, 2012 | Toshiba 62MX195 62" HDTV
Lamp light is flashing...tv will not come on
Bad lamp or ballast which powers it or you name it in these sets, The lamp and ballast are the places to look first.
Lamp on average has two thousand hour life span which is about two years.
Apr 04, 2012 | Mitsubishi WD-62825 62" Rear Projection...
My Mitsubshi DLP TV has a very weak lamp that comes on but does not stay on. Is the lamp the problem?
it is very possible the lamp is the problem but the only way to know is replace it.
Average life span is about 2000 hours which for average viewer is two years.
Mar 13, 2012 | Televison & Video
Tv on my samsung p4663w/hl does not turn on. lamp light flashes on front of tv picture does not work. no sound , bulb has no marks on it to show that it is bad
Tv projection lamp have a life span like any other bulbs light sources.Tipically life spans of these tvs projection lamps are around 20,000 hrs of useages.That average out like about 1 1/2 or 2 years and around 4 or 5 hours of the tv is on and watching it everyday.Now the front tv bazel frame of the tv.The word "LAMP" LED light indication is on or flashing are indication of the tv projection lamp life span are over and the tv must have it projection lamp to be replacement to another tv projection lamp.Projection Lamp fillerments tipically dies out when it reaches it life span.Mark or burns on the projection Lamp,will not show or be there,if the tv projection lamp run it natural life span cycles.
Aug 03, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Television turned off and red light under lamp is lite. Televion will not turn back on. Is this just the bulb blowing out or is it something worse?
This is a common problem for DLP TV's the average time for the life span is 6000-8000 life hours witch is a average time of 2-3 years of use if you have not replaced the lamp before I recommend you do that first and that should fix your problem and be careful when you buy a replacement make sure it is a Philips not a Generic I found the lamp you need and it is a Philips
http://www.discount-merchant.com/UX21513-LAMP-p/hitachi-ux21513-housing-h.htm
Oct 04, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Oct 07, 2009 | NEC NP100 Projector
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
