Question about Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display
Parrot kit has stopped working since new car battery was installed and now all i get is a blank screen on the car kit
Parrot Troubleshooting
http://www.modaco.com/topic/268599-the-htc-kaiser-61-performance-update-is-here/
May 07, 2013 | Parrot 3200 Ls Color Handsfree Bluetooth...
Recently I replaced the battery on the steering control part of my parrot kit and it worked well for two months but now I have a blank screen on the visual display. What would have caused this ?
It sounds like the kit has had a software freeze, you will need to remove power from the Parrot Blue box and replace, if this works then I would also perform a software update.
Nov 26, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
My parrot mki9200 does not turn on i press all the buttons but still does not turn on please help me solve the problem
I had the same problem. stopped turning on one fine day after a little more than a week of installing. then started working again after a few months. realized that it turned on when i thought i had lost it for good. then i also realized that the other instruments in my car were reset, like clock, radio etc. then realized that someone had removed the batteries and installed it again. the clocks restart when you do that. then i realized thats what must've worked and i was right. keeps 'not turning on' from time to time nowadays as well. but works every time i disconnect the batteries and connect them again. like restarting it. hope it works for you too...
May 06, 2011 | Parrot SA Parrot MKi9200 Advanced Color...
I have a parrot ck3100 and had it installed and it worked well for a day or so then it stopped audio from the parrot. It still says connected but no sound is heard from any function. Can anyone help?
If the parrot kit sound comes from your car speakers and your radio is working then the problem may be a wire in one of the connectors that are plugged into the Parrot blue box, I have seen wires pushing out when the plug is inserted.
Feb 27, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot MKi9200 car phone and IPOD problem. 18 months old and worked fine until moved from bmw to golf mark 5. IPOD now not recognised (any IPOD) have done a restore factory settings without success. ...
A replacement blue box is nearly the same as a new kit. I would do a software update on the Parrot and make sure you do a reset on the ipod, back up the ipod first. I would contact a parrot certified installer if this does not cure it. Parrot web site will have a list of installers. If the kit powers up the blue box is not faulty.
Feb 21, 2011 | Parrot Mk6000 Bluetooth Hands Free Kit
LCD is lit but blank and unit no longer responds in any way. It's a CK3100 installed in a Hyundai Sonata 2009
First, you will have to ensure if the trouble is simply on the screen or the car kit, then pair the phone and use it.
If it works, then the screen is the trouble and in that case you will have to get in touch with the supplier or the manufacturer.
Aug 04, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display Logo
Top Parrot SA Cell Phones Experts
Outback Jack
Outback Jack
Miroslav Rusev
Miroslav Rusev
Level 1 Expert
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
