Question about Zebex ZBA Z-3051HS Barcode Scanner - P/N ZB3051USB Handheld Barcode Scanner
Zebex z-3051hs program downlod - Zebex ZBA Z-3051HS Barcode Scanner - P/N ZB3051USB Handheld Barcode Scanner
Need driver for z-3051hs barcode scanner
Hello. The problem will get resolved by going on the links below and download the driver for your Z-3051HS Barcode Scanner.
LINK 1 (Auto Sensor Standard Firmware Version 1.10)
LINK 2 (Standard Firmware Version 1.10)
The links above belongs to ZEBEX official website.
Easily save the file to your computer. Run and install it properly.
I hope I helped!
If you have any other questions, please leave a reply.
Thank you for using FixYa!
May 31, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
I HAVE 5 SCANNERS, FOUR OF THEM SCAN AS THE ITEMS PASSES IN FORNT OF THEM AND THE FIFTH ONE NEEDS TO PRESS THE BUTTON. HOW DO I CHANGE THE FIFTH TO SCAN AUTOMATICALLY
If you look in the manual, you will see the code to place the scanner in to "stand" mode which should do as you request. This mode is restricted to certain models however. Near as I can tell, there are a few variants of the Z-3051HS model that support this. Reference the manual at the link below. Please update this with any other questions you may have.
Thanks,
Dan
Link: http://www.zebex.com.tw/old_website/documents/users_manual/handheld/z_3051hs.pdf
Apr 02, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
WHERE CAN I DOWNLOAD ZEBEX Z-3080 SCANNER SOFTWARE?
This device needs no software. You first need to set it up with the configuration card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf). Then it should scan the barcode number in to the selected text area.
Mar 24, 2010 | Zebex Z-3080 Handheld
How to read data from zebex pdl-20
Use WinTaskGen to download data from the device. If you need the program I can send it to you
Jan 06, 2010 | Zebex PDL-20 Portable Terminal
Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
Dec 28, 2009 | Zebex ZB 2200AM
How do i configure code 128
You need to set it up with the config card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf).
Nov 09, 2009 | Zebex Z-3080 Handheld
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
Zebex Z-3080 - prefix ? software ?
Please download the Programming Guide from the link http://www.zebex.com/documents/Users'%20Manual/A.Handheld/Programming%20Guide%20(MUL-53221-07).pdf.
Attached please find the samples for programmings.
Aug 15, 2006 | Zebex Z-3080 Handheld
Zebex ZBA Z-3051HS Barcode Scanner - P/N ZB3051USB Handheld Barcode Scanner Logo
89 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
