Question about ASUS Computers & Internet
How do i get the numbers pad to work - ASUS Computers & Internet
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Number pad does not work
try another keyboard. to check as it is a software for hardware problem
Jan 16, 2010 | Computers & Internet
The number pad is not working.
did you try shut off brakers one more time? wait for a min or 2 and put it back on..see what is happend....but most likely you need new touch pad
Aug 25, 2009 | Jenn-Air Ovens
ou may need to format your computer.using a laser keyboard may not help.
Apr 29, 2009 | Compaq Presario 5000 PC Desktop
After pressing the TIME button, the number pad does not react.
A hard reset, that is, removing the unit from the electric source and restarting it after a few seconds, solved the problem.
Apr 05, 2009 | LG LMV1630 Convection/Microwave Oven
N81 8gb,keypad lock switch not working
check kep pad connector
or - chnga ic
Mar 26, 2009 | Nokia N81 Smartphone
Labtec USB Number Pad for Laptops with 2 extra USB Ports
I bought this number pad and had the same problems.
I found this fix. download this from the labtec site. http://www.labtec.com/pub/techsupport/keyboards/usb_numpad_for_notebooks_1.0v.exe This worked and the number lock off changed from grey, number lock off to, yellow number lock on and back again.
This appears to be a later driver update.
Mar 17, 2008 | Labtec USB NUMBER PAD FOR NOTEBOOK 2 BUILT...
Number pad not working
the number pad not works mostly when water enters into the mobile. please get your mobile to a qulified technician or motorola service centre.sometimes when excess data is stored this happens.Ayalvas(0)9903881244
Mar 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Computers & Internet Logo
13 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
