Question about Hunter Dryers
Clicking Noise Hunter fan Model 236883 - 60" 3 speed: Clicking noise where wires connect to ceiling - base unit spinning but speed control not working
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
SOURCE: Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Posted on Jun 18, 2009
  • 97 Answers
SOURCE: griding noise
Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
Posted on Jun 29, 2009
  • 1114 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Posted on Jul 21, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
Can a the transmitter and receiver be replaced by wall control for a Hunter fan model 28425?
The part # you need is 85662-01-000. Maybe you can find it somewhere in cyberspace.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
I have a model 51049 Hunter Louden brushed nickel low profile ceiling fan with light; my electrician installed it, but there is a noise like a piece of metal being hit, a scraping noise, which occurs
I have the exact same fan with the exact same problem. I kept taking it apart and could not find the problem until I got it completely apart and took the big housing off. I saw the problem immediately. A couple of the wires were hanging too low and scraping on the round drum that spins. I'm glad I found it, because over time this would have worn the insulation off the wires and created a problem. A potential fire hazard even. I took one of the stiffer solid wires coming from the ceiling and used it to loop around the flimsier stranded wires that were hanging down and scraping. I rolled it all up tight as close to the ceiling as I could and put it all back to together. The fan is beautifully silent now.
I installed it myself. That's my excuse. Your electrician should know better and if he made the rookie mistake of not clearing those wires, he should take it apart and fix it himself for free.
May 06, 2014 | Hunter Dryers
Model cd 52
Check your wiring connections and make sure everything is OK. Also check your capacitor and make sure everything is OK there too.
Aug 15, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter ceiling fan with a remote control model number 85095. The remote will turn the fan on and off and change the speeds but it will not turn the light on or off anymore. Any help?
Make sure the wires to the light kit are connected to the light & light wire connected in ceiling.If that's not your problem then you probably need a new receiver. Call 1-888-830-1326 and have your FAN model handy.Should be a five digit number beginning with a 2.
Jan 14, 2013 | Hunter Ceiling Fan Remote Transmitter...
Someone helped me install a ceiling fan. I told them that I here a clicking noise still , they said to go back and tighten every screw. I did that but the clicking noise is still their. What are my...
Check that all the blades are aligned when the fan spins. If one blade is higher or lower than the others it throws the fan out of balance and makes a clicking noise. Also check that the pitch on all the blades is the same, this has the same effect. The blades can usually be bent just a bit to correct any misalignment.
Jun 09, 2011 | Hunter (25417) Ceiling Fan
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Lightning causes ceiling fan to make clicking noise
sounds like surge shorting
call in an electrician to check the installation of the unit
Aug 06, 2017 | Hunter 20761 52'' The Stratford II Brushed...
Fan makes grinding noise when on speeds two and three. . . sounds fine on slow
The bearings are wearing out, speeds two and three are exerting enough force that the bearings are grinding, slow speed does not have enough force to do this. Soon enough, slow speed will make that noise and the fan will ultimately stop working. Have an electrician come in to look at it, if it is still under warranty, call Hunter.
Sep 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Dryers Logo
18 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
