Question about Whirlpool LER5636P Electric Dryer
The pulley fell off and I don't know where it goes? My belt is fine, need instruction on how to repair and how to get the dryer apart to repair it.
  • 547 Answers
Take top off and front the pully wheel goes on the side of the wall you will see when you open up what side it came off of . thanx for using fix ya
Posted on Jun 19, 2009
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Maytag Dryer- Drum not rotating (belt and motor both work)
I surely do hope this fixes it all.
The pulley that fell apart is supposed to. Well, not quite. It is not fastened inside the machine, and comes off easily. It is the belt tensioner. It fits into 2 slots on the bottom steel panel of the machine (The base)
You will be finding it is a pain in the neck to put back on, but you can do so. The belt goes with the grooves toward the drum, not away from it. The belt goes in a S shape around the motor pulley and the tensioner pulley. One you put the tensioner back in it's place nin the two slots, you will push (or pull) on it against the spring arm to "bend" it so as to get the belt back on.
Be blessed.
Jun 19, 2013 | Maytag Dryers
Remote for appollo 1996 fell apart need to know how to reassemble
Replace it, they don't provide repair instructions for this type of device.
Nov 05, 2012 | Cars & Trucks
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
Makes a strange noise, as if something is rubbing. The dryer works, I took off the bottom front panel, and evrything seems fine, ie the belt looked fine, no debris found.
Most noise complaints from this style dryer comes from the idler pulley and two drum support wheels. The idler pulley just clips into the bottom of the dryer and keeps tension on the drum belt. The drum rollers have clips that must be removed from the shafts before trying to replace them. If one wheel is worn out, replace them both = less problems later on. See "how to take apart" to access the rollers, once the belt is disconnected from the idler pulley and motor pulley, lift out the drum. The roller on the left has a bracket and 2 clips to remove before the roller can be replaced. The right roller has just 1 clip that must be removed to replace the roller. Use a cloth or fine sand cloth to clean up the shafts, use a light oil before installing the new rollers. DO NOT use a heavy grease as this will attract dust and become very dirty and gum up the rollers. Check the belt will you are there and clean out any dust from motor and from the drum base. See how to take apart information. Anew picture of the roller, shaft and clips... you can get the required board and components at ----- www.partselect.com -------- or from ------ www.repairclinic.com ----
if you are not familiar with doing this you can get it done by local appliance repair technician familiar with this model.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Kenmore Dryers
Belt tension part. it fell off and i need to know where it goes on the dryer. Kenmore 80 series gas dryer.
The bracket goes into holes on the floor beneath the motor pulley and looks like the picture of whirlpool in the link below when properly mounted:
http://www.applianceaid.com/images/belt-config.JPG
Oct 29, 2009 | Kenmore 62602 Electric Dryer
Belt replacement
Visit youtube.com and type in Kenmore dryer repair. You'll find step by step instructional videos to service your unit.
BUT.... You've probably burned a belt, but this may only be a symptom of another problem. Something caused the belt to freeze up and burn on the motor pulley.
Check the roller bearings while it's apart... Make sure that the motor's turning free and all related rollers, pulleys etc are in good shape... save yourself from having to open it up twice..
Good luck and let me know how it goes.
k
Jun 22, 2009 | Kenmore Dryers
Whirlpool dryer len2000pw0, starts fine, heats up, but will not spin?
Hi, you will need to change the belt. Here is how:
Normal 0 , UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Jun 05, 2009 | Whirlpool LEN2000PW Dryer
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
