Question about Garden
Rpt 3000 will not rev
Idles fine, but will not rev when pressing the throttle
emjem74
  • 162 Answers
SOURCE: zx6r 1999 G2 starts fine when up to temp throttle
i would try to map the fuel system as it sounds like its totally out? ive never heard of it affecting it that much? also try replacing air filters.
Posted on Mar 05, 2009
  • 200 Answers
SOURCE: vz 800 idles wont rev just stalls
Put your kickstand UP, it has a kill/safety switch on it....Good Luck to you sir, contact me any time...Tim
Posted on May 13, 2009
  • 733 Answers
SOURCE: hesitates at wide open throttle
Could be as simple as new wires. Try turning on the truck at night and check to see if your wires are not arching to the engine block/manifold. Trust me if the wires are bad you'll see it at night. If they are, they need to be replaced along with the spark plugs as this will foul the plugs because of impropper detonation.
Posted on Nov 06, 2009
  • 90 Answers
SOURCE: Fzr 250 Wont rev when cold
Hi!!
Firstly clean the air filter.
and then the carb too needs cleaning.
You can use a good fuel addative to clean the carbs.
There is a YESI a tube that runs upwards from after the carbarator ... if there is any kind of leak in this you will need to change it immediately..
An advice...Pls dont ty to fix any leak on this using any type of solution, it ALWAYS backfires....
Regards
Berry
Regards
Berry
Posted on Jan 31, 2010
SOURCE: 98 Chevrolet Silverado runs rough at half throttle and past.
try removing the EGR valve and clean inside of it and manifold
Posted on Feb 17, 2011
Idles fine but revs up and down even when foot to the floor on the throttle
Sounds like the throttle position sensor is out of sync or gone bad..
Feb 13, 2014 | 2007 Honda Odyssey
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
Car starts fine idles fine wont rev up wants to stall if you give it gas
Could be the throttle position sensor, or low fuel pressure.
Feb 25, 2013 | 2000 Toyota Corolla
My Toyota Quantum 2.7GL idles but does not rev up. i ve changed the fuel pump and filter but still it starts, idles but does not rev up when you press the accelerator?
We do not have this model in US, but I assume it is a new model 2016-17. You throttle (and the "rev" ) is controlled by the computer. The fact that your car is idles - should mean that your computer is fine! There are two types of idle control: 1st- when you have a bypass of the throttle, which lets the throttle flop stay close while idling and let's the air into the motor through a bypass and electronically controlled idle switch. Inspect your throttle - the electronic/metal unit located on the large pipe through which the air gets into the motor: if you have a "bypass" for the air then you need to inspect your throttle body as it could be your problem.
2. most likely you do not have a bypass and your idle is controlled by your throttle body, then it is sure working fine and your only issue is that your engine computer does not know that you press the accelerator. Your gas pedal has an electrical unit on it which connects to the engine computer- inspect the connector/wires if all looks fine most likely your accelerator sensor does not work- you need to change the gas pedal unit ( I think it called accelerator sensor).
Good luck.
Jan 05, 2013 | 2007 Toyota Quantum 2.7
Engine starts and idles fine, but will not rev up (2001 Jeep Grand Cherokee 3.1 diesel auto)
If it was a fuel shortage the engine would rev but to limited speed. This is a lack of air to throttle body. Check for clogged air filter and all the piping and the throttle body.
Sep 28, 2012 | 2001 Jeep Grand Cherokee
1992 Ford Ranger 4.0 starts, runs and idles fine sometimes. then the next time I start it, it idles rough
your choke Is stuck on the Injector/carborater. when you press the gas It Is lettIng to much aIr In. check the cable on Injectors or If It Is carb get some carb cleaner from your local automotIve retaIler and take the breather off and spray carb. also check around It to kake sure the cable Is.not streatched nor caught.
Feb 23, 2012 | 1992 Ford Ranger
Engine idles fine but when throttle is pressed it boggs down and stays down untill you depress the throttle. will not drive
Sounds like clogged catalytic converter. Remove the exhaust pipe from the manifold and try it. If it revs ok, you have a clog.
Aug 24, 2011 | 2001 Dodge Neon
I have a 2002 durango 4.7. I have a hard time starting it hot or cold.when i get it started it idles fine for a few minuts and then rpm drop and wants to stall out,The truck runs great wile driving but...
First off, how new is your battery and how many miles on the D? Dodge vehicles are very sensitive to a failing battery. Have it load tested, and if is the least bit flaky, replace it.
After that, the TPS or throttle postion sensor is your next.
As far as the revving up and down above 3000 rpm goes, that is the PCM protecting the engine from over revving.
Aug 04, 2011 | 2002 Dodge Durango
87 RX 7
rx7`s should rev to 3000 when started cold then it should settle to 750 to 1000 after about 30 to 60 seconds.
mine suffers a similar problem. so far I have been told various answers, mostly involving the bac valve, lambda sensor, air flow meter, etc. try starting of by adjusting the idle adjust screw (on top of the throttle body under plastic cover) this may be all it is. I have not had time to do mine. Its been fine otherwise and idles fine after a few minutes. mine is non turbo 87.
Jun 04, 2008 | 1987 Mazda RX-7
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
