Question about Microsoft Windows XP Professional for PC
Winload.exe cannot run on win32 mode
Aspire
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
You probably have the wrong install file for this program. Usually software will have a 64bit and 32bit version.
Posted on Sep 27, 2016
5 Suggested Answers
acdr
  • 1913 Answers
SOURCE: c: application cannot run in win32 mode ...huh???
may be your system restore disk omnly supports system 64 .
Posted on Nov 14, 2008
love4ce
  • 52 Answers
SOURCE: d:\setup.exe is not a valid win32 application
I don't the problem in the drive, please try to copy the file to your desktop then run it again the same error appears, download the installer for your windows then try from the CD
Posted on Dec 08, 2008
SOURCE: winload.exe problem
is this ur oprating is on other than c:\ drive if yes then then u r not able to do to stop this error simply move ur data then install on the c
: drive then after u can create the clonr without error
please vote for me
Posted on May 19, 2009
  • 156 Answers
SOURCE: Descrapplication can not be run in win32 modeibe
To correct and solve this error follow this procedure
Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
Stop wscript.exe process if available by highlighting the process name and clicking End Process.
Then terminate explorer.exe process.
In Task Manager, click on File -> New Task (Run…).
Type “cmd” (without quotes) into the Open text box and click OK.
Type the following command one by one followed by hitting Enter key
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
Type “regedit” (without quotes) into the Open text box and click OK.
Navigate to the following registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed)
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Posted on Jul 22, 2009
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
Winload.exe
Hi there.
When you turn the laptop on, keep pressing Alt+F10. This should open the recovery program. Follow the on-screen instructions for factory settings.
Let me know if this does/doesn't work.
Tim
Apr 19, 2009 | Acer Aspire 3680 Laptop
Can't boot and get winload.exe and ntkrnlpa.exe errors
If you reinstall windows just make sure you do it on the partition it was already installed. If it was not installed in D as long as you do not delete or format that partition you will not lose that data or the partition.
As for your errors you will need to reinstall windows if you cannot repair the already installed partition.
Feb 06, 2009 | Acer Aspire 9300 Notebook
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
D:\setup.exe is not a valid win32 application
Dec 04, 2008 | Microsoft Windows XP Professional With...
Black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
Sep 30, 2008 | Acer Aspire 5315 Notebook
Error: "The application cannot be run in win32 mode"
Open my system, click mycomputer and then opening only c drive, but D,E,F drives are not opening, if telling application cannot be run in win32 mode ( how can i solve the problems.)
Jan 07, 2008 | Microsoft Windows XP Professional for PC
Open drive
Go to Start/Run and type :
reg.exe add "HKCR\Drive\shell" /ve /d "none" /f
then type:
regsvr32 shell32.dll
Dec 18, 2007 | Microsoft Windows XP Professional for PC
Smss.exe virus remove
I run spybot and hijackthis in safe mode.
Dec 15, 2007 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
