Question about Air Tools & Compressors
Husky m1506f Air compressor will not turn on
On/off switch is lighted but will not turn on. Is there a fuze or something?
1.5 hp, round 6 gal tank with compressor on top under a plastic shroud
  • 47 Answers
Look for a reset circuit breaker button on or near the compressor motor. It might be black in color.
Posted on Jun 22, 2009
I need a capacitor(s) for my husky air compressor where can i get one
I just bought a few my self , try "Drillspot" good service and prices.
Don F
Aug 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Dent in air compressor tank
was the tank creased? you can take it to a compressed gas refiller and ask them to pressure test the tank.
May 25, 2009 | Air Tools & Compressors
I have a husky compressor, model number y6010-wk. it builds pressure slow, and shuts down right away.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Feb 27, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My husky pro vt631402aj verticle compressor won't stay running when compression rises
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Air Tools & Compressors Logo
432 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
