Question about Boating
Yamaha 40HP 2 stroke 3 cylinder Autolube
Oil Pump adjustment - smokey at low revs
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 125 Answers
SOURCE: I have a 1978 Yamaha DT175E. It is runnig rough
Check the choke to see it is not stuck on.
Something is causing the bike to run rich as you said.
Make sure the throttle slide isn't stuck and is working ok.
Try a smaller size jet.
Posted on Jun 15, 2009
  • 23 Answers
SOURCE: Yamaha 30 HP 3 cylinder 2 stroke
Did you change plugs? If you did chek the plug to see if piston has hit the end of plug. Do a compresion check Jim OMC retired Mech
Posted on Jul 07, 2009
SOURCE: I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke
all 3 carbs had A  clogged jet totally dis assembled and cleaned the carbs put them back on and the engine runs great I will need to fine tone the needle valves once I put some fresh gas in it.
Thanks John
Posted on Jul 09, 2009
  • 232 Answers
SOURCE: l50deto 2 stroke outboard stalling at high revs
fuel pump could be the cause but also the float in the carby could be not set at the right level and starve the motor at high revs .
Posted on Sep 29, 2009
Testimonial: "I found the solution, carbs werent clean enough. Got a compressor in there and solved it. Thanks anyway"
I have a 40hp yamaha outboard it starts great but when i put in gear it stops
If it's a 2-stroke, have those carbs cleaned...
Then check if he runs on all 3 cylinders.
Aug 11, 2017 | Yamaha Boating
How do I adjust the oil injector pump on a 72 yamaha enduro
Hi, John for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $15 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://mybikemanuals.com/yamaha/yamaha-dt
OEM parts for Yamaha
DOWNLOAD NOW Yamaha DT250 DT360 DT 250 360 Service Repair Workshop Manual...
Vintage Enduro Discussions Fuel to oil mix ratio 1 1
TWO STROKE AUTOLUBE OIL PUMPS
Dec 22, 2013 | 1972 Yamaha DT 360
How to adjust the oil pump of Yamaha DT125R?
Hi, James sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Setting Pump Oil Yamaha Autolube
Autolube Settings On My Yamaha DT125RE
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
Aug 17, 2013 | Yamaha DT 125 R Motorcycles
Oil pump adjustment
Hi, James for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
I have just picked up a 1967 yamaha yl2 100cc bike, can someone tell me what grade of oil to run in the autolube system please?? Thanks
On a machine as old as this any present-day 2-stroke oil will outperform the original manufacturers specification.
Apr 30, 2011 | Yamaha RD 250 Motorcycles
I have a 1972 Yamaha R5,made into a three wheeler(ATC).What is the correct fuel/oil mixture??
The R5 had Autolube....which is automatic oil injection....no gas/oil mixing....there was an oil pump in the crankcase, with one cable from throttle running to the pump so pump stroke varied with throttle opening.....the oil tank for the injection oil was under the seat on the right side.
Apr 10, 2011 | Yamaha RD 350 Motorcycles
How can i fix my oil pump for my bike yamaha DT125 1981
Hi, Adelalmansoo sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/23188-dt125r-dtr-dt125-oil-pump-problem
Yamaha DT 125 problem
Yamaha Motorcycle Manuals
Sep 29, 2010 | 2000 Yamaha DT 125 R
My topboy (2 stroke) motorcycle problem is overheating
is this a 2 stroke scooter? if it is, try to premix your gasoline. and try to test it. if it works, then your autolube has a problem. if it is a 4 stroke. try to check your coil. and try borrowing another coil and test it.
Apr 12, 2010 | 2005 Kymco Grand Dink 250
2007 Yamaha DT 125 oil pump settings
Hi, Evdbank for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha DT125RE 2005 Service Manual
YAMAHA DT125R Owner Manual
Aug 28, 2009 | 2006 Yamaha DT 125 RE
Loss of power...
hi kev,
thank you for using fixya.
i'm a 2-stroke fan myself, all my bikes are 2 stroke. with the issue you currently have, i would say that the culprit will be the following.
1. carb mixture for oil, air and gas. you may need to have this tuned making sure that the 2-t oil is not more than the gas.
2. body {background-color: #FFFFFF;font-family: "Verdana"; font-size: x-small;} p { margin: 0px 0px 0px 0px; } overheating, there are many points for a 2 stroke engine to overheat even on in idle, one reason is too much oil or too little oil (transmission oil that is). when it overheats, the gas/oil/air mixture will be heated and too denced to burn, leaving it with low combustion and smokey burn.
best way to get through this is to check your piston and rings of any scratch for a possible blow by, and have parts replaced if possible. for the carburator, just set the timing and the tuning to 1:4:5.
should you have other questions, please let me know.
regards,
voodoo
Apr 20, 2009 | Yamaha DT 125 R Motorcycles
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
