Question about Netflix Computers & Internet
Netflix error 405 - Netflix Computers & Internet
    Top Expert:
  • Netflix Master
  • 14,161 Answers
Http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Posted on Oct 23, 2015
What does error code f736333432b0f4610 mean?
hat do the error codes mean?HostMySite
www.hostmysite.com > Support > GENERAL SUPPORT
Browser Error Codes. Linux and Windows ASP.NET, SQL, Coldfusion, and WebMatrix hosting backed by world class 24x7x365 toll free phone support.
Microsoft Malware Protection Center - Error Codes
https://www.microsoft.com/.../errorcodes.aspx
Microsoft Corporation30+ items - Microsoft Security Essentials error codes. The table below has some common error codes from Microsoft Security Essentials. ... See I can't install Microsoft Security Essentials for more details. Error code
Possible reason for error
0x8004ff00
Another Windows installer may be running
0x80070643
This is a generic error code - there could be an undiagnosed ...
Netflix Error S7063-1417https://help.netflix.com/en/node/23463NetflixIf you experience the error code S7063-1417 on your Mac when trying to watch in Safari, use this article to resolve the issue.Why can't I connect to Netflix?https://help.netflix.com/en/node/461NetflixNetflix is Unavailable, Unable to Connect to Netflix, Android Error: Connection Failed ...These error messages are sometimes accompanied by an error code ...Netflix Error S7363-1266-00002E18https://help.netflix.com/en/node/22793NetflixIf you experience the error code S7363-1266-00002E18 while watching on your Mac computer, use this article to resolve the issue.
Feb 03, 2016 | Netflix
Error code c7363-1262-00000024
Netflix error code
NETFLIX CUSTOMER SUPPORT PHONE:
1-888-638-3549
PRESS 0 AT EACH PROMPT.
Average Wait: 5 mins - 24 hours, 7 days
OR
Netflix Calls You Instead
http://gethuman.com/call-back/Netflix/
http://www.netflix.com
Feb 14, 2015 | Netflix
I can't get connected to Netflix.All that pops up is error code 209826
1 (866) 579-7172
this is Netflix customer support phone number. Basically their are at least 9 way to contact them the link is below. Good luck.
https://gethuman.com/contact/Netflix/more
Dec 30, 2014 | Netflix
Netflix error code m7083-2107 windows vista movies wont load and play
Netflix Playback Error M7083-2107
If you get the error code M7083-2107 while watching on your computer, it's typically due to an extension on your Chrome browser that is preventing Netflix from working properly. Follow the troubleshooting steps below to resolve the issue.
  1. Open Chrome if it's not yet open.
  2. In the URL bar, type chrome://extensions/ and press the Return or Enter key on your keyboard.
  3. Uncheck all Extensions.
  4. Try Netflix again.
This is from the Netflix help page
Dec 22, 2014 | Netflix
Help! I'm getting Error N8008 on Netflix (There are multiple Netflix tabs) and there's only 1 Netflix tab
1-888-638-3549
OR
Sep 14, 2014 | Office Equipment & Supplies
My tv works, connected to LAN, Roku had been working fine and picking up my router. It has just stopped, with saying Netflix had an internal error???
1-888-638-3549
OR
Aug 17, 2014 | Netflix
Streaming thru my tv
Error: Cannot Connect to NetflixThe following error messages indicate an interrupted connection to Netflix:Cannot Connect to NetflixCannot reach Netflix.comNetflix is Not AvailableNetflix is UnavailableUnable to Connect to NetflixAndroid Error: Connection FailedMost connection problems that prevent streaming occur on the device itself, or on the home network. In a nutshell, we will have you test the Internet connection on the device, log out and back into Netflix, restart your device, and restart your home network equipment.
Oct 24, 2013 | Netflix
Check engine light is on. error reads PO128 and
hi 128 is coolant temp below regulating temp 405 is
hi 128 is coolant temp is below regulting temp 405 is
hi 128 is coolant is below regulating temp 405 is<erg/swsr/ckt low> hope this helps please rate this answer
Nov 20, 2009 | 2002 Saturn L-Series
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Computers & Internet Logo
49 people viewed this question
Top Netflix Computers & Internet Experts
David Payne
David Payne
L Pfaff
L Pfaff
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
