Question about Refrigerators
GE refrigerator model # dss25kgrc ww freezer fan surges
The freezer fan surges up and down whenever freezer cycles
4 Suggested Answers
  • 864 Answers
SOURCE: GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Posted on Jul 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
Posted on Dec 13, 2009
SOURCE: The freezer shelves in my GE Dss25KGRC side-by-sid...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
Posted on Jan 06, 2012
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
May 21, 2010 | Refrigerators
Dec 13, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
Mar 17, 2009 | GE GSS20IEM Side by Side Refrigerator
GE refriferator cooler side is warm/warming
possible cause the fan motor that takes air from the frezer section may not be working or seizing up check to see if your fan is working after seting your dial at corect numbers thans from gilles
Mar 15, 2009 | GE GSS20IEP Side by Side Refrigerator
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan surges up and down
Don't worry, that is a variable speed DC fan motor. Fan speed is regulated by the mother board as needed.
Oct 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
