Need to access aux/av on Symphonic TV
I have a Symphonic TV with no remote. I cannot access the aux/av mode so that I can use my dvd player. Any idea on how to do this? Thanks.
5 Suggested Answers
  • 1153 Answers
SOURCE: can't get TV onto the AUX channel
Do in your menu have like VCR or DVD in the option area? If so then put on vcr or dvd. Also you can look for the channel in the add or erase area and move past the channel 2 by going the other way and see if the aux or video1 comes on then simply chose it.
Posted on Sep 09, 2007
crazy larry
  • 6 Answers
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Posted on Feb 23, 2008
SOURCE: How do i get my symphonic tv into video mode without remote?
Hi Guys
This will help you a looooot
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 16, 2009
lilmikew99
  • 122 Answers
SOURCE: I can't switch to aux/video without my remote.
not really sure about this but if you put a disk in then run auto scan for your channels,long shot but worth a try.
Posted on May 11, 2009
Need game mode back on television
Use p+ or p- button at the front panel of your tv. AV "channel" usually is between last and first channel.
Jul 20, 2014 | Symphonic Televison & Video
Sponge bob DVD player will work on a regular TV but will not show up on the sponge bob tv anymore. Also tried a different DVD player and only get a blue screen. Shows AV then AV then tv or something. It is...
Hello
Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
Jun 27, 2011 | Emerson SpongeBob SquarePants TV
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
Lost original remote t the symphonic tv which has
You can get the original remote for a decent price. It is an original replacment remote. You can find it at any of these places.
www.replacementremotes.com
remotes.com
www.mr-remote.com
www.neworiginalremotes.com
You will need the original remote to access the features you want to use.
Nov 23, 2009 | RCA DIRECTV Satellite Remote Control
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
How do i/can i record tv to a DVD ]
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Jun 19, 2009 | Symphonic WF803 DVD Player/VCR
Need dvd code for symphonic WF104 I am using a scientific atlanta remote control
I'm guessing you have tried these already, but, you can try:
2017, 2213, 1029, 1134, 1150
if it is the ER1
014, 186
If that doesn't work, try a search by doing this:
Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
AUX) until the mode keys blink twice. For example, to search for a TV code, press
and hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press PLAY . The remote automatically tests each code in its library, beginning with the most common codes. The mode key blinks once each time the remote transmits a new code. The mode key
blinks twice when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press channel up or channel down to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
Apr 03, 2008 | Symphonic WF104
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
Feb 16, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
I cant get aux on my symphonic tv to play
Try Channel down from 2 or up from 99.......T.
Jan 22, 2008 | Televison & Video
DVD player to 27GT623 Television
just press the AV / Tv button from the remote control or press the channel up or down until it reaches the input mode next to the last channel slot.
Jan 17, 2008 | GE 27GT271 TV
Televison & Video Logo
559 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
