Question about Kodak EasyShare DX7590 Digital Camera
My dx7590 will not format memory card
I've put in various SD cards and it says that the memory card needs formatting. I click on continue to format it and it says it formats, but then it won't read the SD card. Can someone tell me what's wrong with it?
SOURCE:
SOURCE: memory card
i have the same problem!!!
Posted on Apr 28, 2008
SOURCE: memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Posted on Jan 02, 2009
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Posted on Mar 28, 2009
SOURCE: sd card will not format
The camera has a limit of a 2 GB card , its built into the camera hardware.
Posted on Apr 28, 2009
leepania
  • 1099 Answers
SOURCE: We insert a memory chip into our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Posted on Jan 04, 2010
Format problem with kodak easyshare dx7590
What type and size memory card? The DX7590 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Feb 21, 2013 | Cameras
Why is my camera going round and round in circle when trying to format my memory card?
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
Nov 10, 2011 | Kodak EasyShare DX7590 Digital Camera
How do i format the memory card on the kodak easy shareDX7590. I just bought and inserted a knew kodak 8 gm memory card and it says it need to be formated and i do not know how and have pushed all the...
To format a memory card, press the MENU button, use cursor-up/down to select Settings, press the OK button, use cursor-up/down to select "Format," and press OK.
The DX7590 works with MMC and SD cards. It does not work with SDHC cards. If you mean an 8GB card, then that's an SDHC card and will not work with the DX7590. The camera is limited to cards 2GB and smaller.
Sep 24, 2011 | Kodak EasyShare One Digital Camera
I am trying to format a 4GB SD card for my camera and it will not format
The DX7590 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to use SD cards 2GB and smaller.
Dec 09, 2010 | Kodak EasyShare DX7590 Digital Camera
Just bought this Kodak Easyshare DX7590 used. Radio Shack sold us a 4 GB SD card for it. When we insert it into the camera, it says "Memory card needs formatting". When we try to format it, it...
The 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller with the DX7590.
Nov 20, 2010 | Kodak EasyShare DX7590 Digital Camera
Kodak DX7590 not reading memory card...
hi. if you can open the camera specially in cards slot, try to desolder and resolder the card slot.some time the loose contact of the pin between the board and cardslot are cause of problem like fromat your memory card,cardlock and not readung the memory.
goodluck my friend
Jul 13, 2010 | Kodak EasyShare DX7590 Digital Camera
I have an 8G memory card that I cannot get formatted for a kodak easyshare DX7590 from a cannon format. What do I do? I've put it in the camera and told it to format it but it won't.
Get an SD card.
The DX7590 works with SD (and MMC) cards. Your 8GB card is actually an SDHC card and thus will not work. You'll have to stay with cards 2GB and smaller.
Jun 11, 2010 | Kodak EasyShare DX7590 Digital Camera
Kodak dx 7590 camera will not format a memory card?
as a short cut try putting the sd card into your sd slot and format it with your computer
May 15, 2010 | Kodak EasyShare DX7590 Digital Camera
Camera will not read memory card
Jan 01, 2010 | Kodak EasyShare DX7590 Digital Camera
Formatting a HP 4GB Memory card
The best thing that you can do is to try to format the card from a laptop with a built in card port or use a card reader and format it on your computer.
Feb 06, 2009 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare DX7590 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
