Question about Garden
Want to make sure there is only one place to change oil on pressure washer and what weight to use?
    Habit-Forming:
  • 80 Answers
FIRST OF ALL WHAT ARE YOU TALKING ABOUT IS THIS THE MOTOR OR THE PUMP THAT YOU WANT TO CHANGE THE OIL ON. SHOULD BE ONE PLUG ON THE MOTOR SOME HAVE TWO YOUR PUMP SHOULD HAVE ONE ON THE SIDE OF THE PUMP
Posted on Jun 14, 2014
4 Suggested Answers
mcgyver468
  • 710 Answers
SOURCE: changing engine oil on a gx390 engine for pressure washer excel
On the very bottom of the motor is a square plug to drain the oil. The machine must be elevated to allow the oil to flow into a drain pan. If you don't see a square plug then look for a small 1/4 inch tube coming from the bottom of the crankcase with a hex cap on the end of it. If you cannot find either of these, then you must turn the pressure washer on its side and drain it through the same plug you fill from.
Posted on Apr 24, 2009
  • 6468 Answers
SOURCE: what weight oil does the briggs & Stratton pressure washer need
sae 30 or 10w-30
Posted on Jun 10, 2012
  • 5245 Answers
SOURCE: what oil weight is used in the pressure washer pressure unit
Non-detergent 20-30-weight goes into pump port, and is filled about half way.
Ordinary motor oil 10-W30 or 40 goes into engine port.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 27, 2012
What oil should be used in the pump of a scorpion spw-2 pressure washer?
http://www.ultimatewasher.com/operators-manual.htm
May 19, 2015 | Garden
What oil to use?
what is recommended in the owners manual if not sure try Google Make model and manual
May 18, 2015 | Garden
What oil weight is used in the pressure washer pressure unit
Nov 11, 2012 | Dewalt Gas Pressure Washer: 4200 psi 4.0...
WHAT OIL SHOULD I USE FOR THE HONDA BM80913A PRESSURE WASHER . I HAVE OIL FOR 2 CYCLE ENGINES BUT I AM NOT SURE IF I CAN USE IT. I do not have the service manual available
If you are asking about the oil for the gasoline engine then you can use a 30 weight engine oil like you would use in a car engine. Pressure washer pumps use a special non-detergent oil which is not the same as the engine uses.
Jul 16, 2011 | Honda Black Max 2600 PSI Pressure Washer
I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
May 09, 2011 | Northstar Pressure Washer 2800 PSI
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
What weight oil do i use in a 5 hp honda ?
For normal use I would use straight thirty weight. For colder use I would change to 10W-30.Thank you. I hope this is what you needed.
Jan 20, 2011 | Honda Maxus Pressure Washer MX5222
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
Timing a 13 hp GX 390 Honda engine
I believe it is either one but if you are not sure, stick a screw driver in an see if it comes out with oil on it. Does one not have an oil level stick attached to the cap?
Jun 18, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
