Question about Craftsman Garden
Mower won't start
I turn key and starter won't engage fly wheel to start engine
    Champion:
  • 279 Answers
Battery charged?,sitting on the seat?, starter or solinoid working? Take out the spark plugs and try turning the engine underneath by using the pulley. Is the oil fresh?
Posted on Jun 03, 2014
  • 127 Answers
SOURCE: Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Posted on Jun 26, 2009
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
wireguy212
  • 1627 Answers
SOURCE: starter spins but does not
Odds are that you have a broken spring in the bendix part of the starter drive,which is replaceable but at the same time is hard to find separate from the whole assembly.The whole assembly will run you about 55 to 90 dollars depending on where you find it.
Posted on Jul 30, 2010
SOURCE: i have a countax a20-50.when starting engine with
I have a Countax A2050 and the deck is not lifting when I press the button on the dash, What is my problem?
Posted on Apr 01, 2011
  • 417 Answers
SOURCE: mower will not start
Don't do any of that. Your battery is toast and cannot hold a charge any longer. It's time for a new one.
Posted on Nov 21, 2013
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
My stater is free,spinning thn grindingmon the stop but it doesnt do it all the ti,me but is slowly getting worste its a 2001 z3 roadster 3.0im i replaced the crank positioning sensor but did nothing...
replace the starter and the flywheel-the bad starter has not engaged the teeth on the flywheel fully and has ground some teeth off so you'll fit that space every once in a while-cheers Denny
Oct 31, 2013 | 1999 BMW Z3
Toro electric starter will not engage
Starter bushing is bad....
Sep 10, 2012 | Toro Garden
1996 manual jetta won't start. It won't even crank. There is a whinning noise when I turn the key from the engine but that's it.
Sounds like the starter drive is not fully engaging with the fly wheel... might try to tap firmly on the body of the starter while you turn the key but be careful not to hit the wires... Might get you going enough to get to a garage and have it checked. good luck!
Jul 20, 2011 | 1996 Volkswagen Jetta
When I turn the key the starter won't engage . but the starter is good and the battery is good .
Check your starter relay if you are positive both battery and starter are good. Best of luck
Oct 18, 2010 | 1999 Oldsmobile 88
GMC Sierra...grinds while turning key.
teeth could be broke off the fly wheel...the fly wheel is what the starter engages with to turn the engine over,,,it looks like a big gear with lots of teeth....check the starter first and see if it is fully engaging.....tap with a hammer while turning the key..sometimes this will release it..thank you and have a great day
Nov 07, 2009 | 1992 GMC Sierra K1500
C230 Key Won`t Turn the car only went i use 14.3V
The starter is turning only when the solenoid close the contact to deliver the current to the starter . When this happens it then turns the bendix to engage with the flying wheel to start the engine.
The reason that you need higher voltage to have correct needed current going through the contact of the solenoid, hence the starter. The contact is corroded or rusty due to high spark at high current at every start time causing high resistance. V=IR the R resistance of the contact now is high so it need higher voltage (14.3 vs, 12.8 V) to deliver the same needed current for the starter.
Unfortunately, the solenoid is integrated with the starter, so you can not just replace the solenoid without replacing the starter.
If you can find the new battery holding at 14.3 V as you mentioned, then that is an economical solution since replacing the starter is costing more.
BTW where can I find the battery at 14.3V in case my friend's car has a same problem?
Jul 26, 2009 | Mercedes-Benz C230 Cars & Trucks
Car starts but sometimes makes a whirling noise. I was told it was the starter
sounds like the starter is not disengaging the fly wheel quickly like it should when you turn the key the starter cog connects upto a fly wheel that has teeth all around it when the teeth of starter cog connect between teen on wheel it spins it to crank your car then goes back to starter if you hold your key on after starting the noise you hear is the starter cog(teeth ) still engaged in wheel if this is the sound it needs to be serviced not neccassarily replaced
Jun 06, 2009 | 2003 Chevrolet Impala
Starter turning engaging not start
 you need a shim, if its screaming your clearance is to great. Are you positive its the right starter?
Feb 19, 2009 | 2003 Ford Ranger Regular Cab
Garden Logo
24 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
