Question about Pyle Pbt30m Ergonomic Wireless Bluetooth Headset Ear-piece
How do you connect your red rock candy Bluetooth to your ps3, and what does it mean when the light turns white?
It flashes red, and it takes forever to scan, and it turns white.
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
My controller pairs but doesnt stay connected it constantly re pairs
Is it an original controller or an aftermarket one? But anyway seems to be a Bluetooth issue. Make sure your ps3 is not tucked away in an entertainment center. That could block the signal. Next plug the controller into the ps3 via the USB cable, see if that works. If so, then go into settings, reassign controller. See if that helps. If not then buy a new controller.
May 28, 2014 | PDP PS3 Rock Candy Controller
How do u sync the new rock candy wireless controller to your wii
To connect any form of controller to your Wii, you need to flip open the flap on the front of the Wii system. There should be a small red button. You must hold that, and then push a pin into the small hole on the back of the controller (There should be a round red button inside of that as well) and hold them for a few seconds. This will automatically pair the controller and system.
Dec 17, 2013 | PDP Rock Candy Wii Gesture Controller...
Alternating red and white blinking light on earpiece for afterglow pl-6360 then shuts off. Unit should be fully charged. Help!
Alternating red and white LED colors indicates that it is not detecting an active bluetooth connection. Use the PS3 bluetooth settings to find and reconnect the signal.
Sep 29, 2013 | PDP Pelican PDP PL6360 Sony PS3 Bluetooth...
How do i turn on my ps3 rock candy wireless controller
After installing batteries in the controller and inserting the usb stick into your PS3, hold down the home button (the round middle most button with a house on it) for a few seconds until the light on the controller illuminates. This is your indicator your controller is paired with your PS3 and should be assignable and usable at this point.
Apr 08, 2013 | Video Game Consoles & Games
Connect Rock Candy Wireless remote
I just got the pink wireless wii controller by rock candy and i cant figure out to sync it. it comes with a usb drive. do i need to connect it or just plug in the usb drive and be done?
Mar 28, 2013 | PDP Rock Candy Controller For Playstation...
When i turn the ps3 on the red light terns green ,then blue ,then white ,then back to a flashing red
ps3s do not have a white light but the red flashing one at the end means you have a critical hardware failure something has died on the circuit board usually the cpu or gpu cannot be fixed easily if you dont know much bout electrical stuff but it can be done, but first id check if the console is under warranty if so return it for a brand new one
Oct 06, 2009 | Sony Playstation 3 (PS3) Console
How to pair the bluetooth headset to the ps3
This is the info i got when i was looking to pair my headset with my PS3.
1. Turn your bluetooth headset on. It should flash on/off every few seconds.
2. Go to Settings > Accessory settings > Manage bluetooth devices.
3. Put the headset in "pairing mode".
4. Start to scan for the device. PS3 should pick it up. It will display the model if successful.
5. Once it's found it hit the options button. Connect the device (pairing mode) A blue icon will pop up.
6. Your headset will stop flashing meaning it has connected successfully.
7. Go back out and click on the audio device settings.
8. Input device > select "your headset". > output device > "your headset".
9. Hit the "connect bluetooth" icon. Then OK.
10. Your headset should now be successfully connected.. start talking into it to see the bar level move up and down to confirm its working.
Hope it helps.
Best Wishes,
Karlos
Jun 28, 2009 | Radio Communications
How do i fix flashing red light problem?
If its a little red light that flashes when ur ps3 is turned on thats your controllers connection light it might mean your controller still conected to the ps3
Jun 04, 2009 | Sony Video Game Consoles & Games
Pyle Pbt30m Ergonomic Wireless Bluetooth Headset Ear-piece Logo
Top Pyle Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Pyle Radio Communication Expert? Answer questions, earn points and help others
