Question about Karcher 2500 PSI Pressure Washer
Wouldn't start. Starts immediately when I spray starter fluid into it (then stops). Disassembled carb section cleaned spider nest from intake manifold vent (suspected cause of problem. Reassembled. Now leaking fuel profusely from carb side (I think) of fuel tank bracket. Gaskets on both sides of bracket look OK but???
  • 2 more comments
  • bonesbba Jun 19, 2009
    Can't try that until I reassemble the whole thing, but can we explore other possibilities first? The fuel really runs down from the area I mentioned and I don't think I really choked it enough to cause that much fuel to pour out. Can you suggest another possibility? One of the on the tank mounting bracket fell off when I first disassembled it, but I super glued it back on and they look serviceable. I don't think i ever had all that fuel leakage when I over choked it before I had this problem.
    Can't choke it, start it, then unchoke it because it doesn't start. Just leaks.
    I don't think the leak is due to over choking (although I know that's possible)because I tried starting twice and don't think I over choked. The last expert is fixated on that one solution. Can you suggest another possible explanation for the excessive leaking before I repeat the process of completely reassembling the whole carb and intake section????
    I'll put it back together and try again, but don't think we've found the problem. If it doesn't start this time I'll just take it in to the shop.
    Bonesbba
  • 1,959 Answers
Definitely sounds like a gasket issue. Anytime a carb or manifold is taken apart, it's a idea to replace the gasket. Old gaskets are compressed and can compromise the seal after reassembly. A new gasket(s) will assure a proper seal and prevent leaking. Apart from this, it's possible to overtighten and distort the gasket, preventing it from sealing properly.
I think replacing the gaskets and taking care not to overtighten the carb (you can test it before tightening further) will solve your leaking problem.
All the best!
Greg
Posted on Jun 19, 2009
  • Greg Margossian
    Greg Margossian Jun 19, 2009
    OK, be sure to use new gaskets and it just came to me, check the gas line fittings to the carb as well. A worn fitting on either end would cause a large gas leak.
    Sergeant:
  • 321 Answers
Well make sure you choke it, then try starting to make see theres no flooding and then unchoke it and then try starting. To much fuel in the chamber.. and when you keep starting it, it keeps pulling the same amount so make sure you choke it start it, then unchoke then try./
  • dino kalameros Jun 19, 2009
    that is a problem. I will say that the leaking is a problem, but if it wasnt happening before you disassembled it then im sure its not the issue! but i looked up this brand and its a pull motor, I used to try to start a chainsaw over and over and over again> fuel oil mix is good but for some reason most pull engines wont start unless you Choke it, then pull the motor leaving a back pressure in the chamber, and when you release the choke this should start it first try, there should be a choke switch and older motors dont have this its a pully not a switch but yours is new.but i only assume this because its happened to me.If its not the choke their could damage to a fuel line or to a part unseen . the leaking will cause under pressure and it may not start at all, make sure the gaskets arent damage and even if not, they may be different sizes due to storage or weahter.
    i cant say it could be anything beside motor damage but i dont see that. if it turns when you pull its should mean its ok.
Won't hold fuel pressure, just replaced spider injector system. No ck eng lite no codes. starts fine, runs rough. I'm looking for suggestions.
Harriet, spray some starter fluid at each injector to see if they are leaking air in at intake, they may not be seating correctly,
Feb 23, 2016 | Cars & Trucks
Cranks, no start on 97 GMC van with 350 Vortec. Fired up with starter fluid
if it starts with starter fluid then its a fuel problem. check the fuel pressure and volume with a gage. these require at least 56lbs pressure to open the injectors and if the pressure is at 52lbs the they will not open. these use the pressure to open the poppet injectors and have a problem with the spider lines cracking and leaking fuel inside the intake. this is probably why it won`t start on its own.
Oct 12, 2014 | Cars & Trucks
My 1993 suzuki gsf 400 bandit will only start if i spray starter fluid into the intake on the breather or if i jump it off !
The carburetor choke circuit is probably plugged up. Remove the carbs and thoroughly clean them making sure that the choke orifice are especially opened.
Nov 16, 2012 | Suzuki Motorcycles
Out board moter problem
sounds like a carb problem open it up and clean it
Jun 11, 2012 | Garden
Not getting fuel. If I spray starter fluid into the intake it momentarily starts... then dies. model PRK17G42STB
Hi, The carbereter needs to be cleaned out. After sitting for a season (WINTER) the carb will gum up and you will have to clean that out. Try using a product like carb clean or gumout sold in many automotive parts stores. Good luck.
Jul 13, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I left my Suzuki DR-Z 125L out throughout the winter and now its trying to start but it wont. I replaced the spark plug and put in new oil.
Clean the air filter then spray some starting fluid in the carb intake. The carb may be a bit gummed up from gas evaporating over the winter. If so, clean the carb with spray carb cleaner. Be sure the float starts and stops the flow of gas properly.
Apr 10, 2011 | 2005 Suzuki DR-Z 125 L
I have to spray starter fluid in the intake to start my blazer
that indicates you have a fuel supply problem. a plugged fuel filter, or a fuel pump thats loosing its pressure. usually when you put starting fluid in throttle body. and it starts. thats a fuel problem.
Jan 13, 2011 | 1996 Chevrolet Blazer
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Will not start need to clean carburator but do not know how
Get a can of starter fluid and a helper. One person sprays starter fluid into the air intake and the other starts it. let it run on starter fluid for a minute as this will clean the carburator. Joe
Mar 15, 2010 | Garden
Bike left standing for 6 months won't start
Hi, Sitting not good ! That is why the petcock has an off position. Spray some starter fluid or some fuel in the carb intakes and see if cranks, If it does, the carbs have to be disassembled and cleaned. Good Luck to you!
Feb 25, 2009 | 1990 kawasaki ZZR 600
Karcher 2500 PSI Pressure Washer Logo
105 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
