Question about Microsoft Xbox® 360 Core System Console
Had drive not detecte - Microsoft Xbox® 360 Core System Console
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My acer aspire 5100 does not detect the Pen drive
If your laptop will detect any other USB drives ....if other usb device detects make sure ur pen drive is affected with virus or pen drive detecting problem
Oct 24, 2010 | Acer Aspire 5100 Notebook
After windows sp2 update
0141 error is no hard drive detected. So boot to the BIOS F2 at boot and ensure that the BIOS is seeing the hard disk drive. If it is not, then reseat the drive/drive cable connections and try again. If the drive is detected in bios, then try booting to WIndows, if HDD never is detected, reset bios defaults and reboot, and see if it detects, if still not detected, replace the hard disk drive
Nov 01, 2009 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
My bios doesn't recognize my hard drive
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
Mar 03, 2009 | Seagate Barracuda 7200.7 200 GB Hard Drive
Won't boot off of the external drive
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Apr 12, 2008 | Dell Latitude X200 Notebook
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Microsoft Xbox® 360 Core System Console Logo
12 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
